November 22, 2008, 07:49:20 PM
| | |-+  wheel lug pattern
Author Topic: wheel lug pattern  (Read 299 times)
goober86442
wheel lug pattern
« on: June 15, 2006, 06:04:42 PM »
Hi all. I was just wondering what the Wheel lug patten is on a stock 1973 dodge swinger rear end? is it 4.25 or 4.50?
Thanks.
duster
thebankerstoy
Re: wheel lug pattern
« Reply #1 on: June 15, 2006, 06:32:51 PM »
It should have the large bolt pattern, which is 5 on 4 1/2 inch.
The only other thing that it might be, is the small bolt pattern, which is 5 on 4 inch.
Richard
Saint Paul, MN
« Reply #2 on: June 15, 2006, 08:10:37 PM »
If you have front disc's, you have the 4.5" pattern. If you have drum brakes all around, you may have 4" pattern.
'67 Notchback- 12.85 @ 109mph
