December 02, 2008, 10:44:13 PM
| | |-+  Wheels and brakes, what do u think?
Author Topic: Wheels and brakes, what do u think?  (Read 1018 times)
FredDart
« on: June 26, 2006, 08:15:56 PM »
I just got my brakes and wheels installed, what a difference it makes!
Brakes are wilwood on 4 corners, wheels are boyd coddington JYD 17x8, 225/45r17 front and 245/45r17
Let me know what u all think
http://frederictessier.spaces.msn.com/PersonalSpace.aspx for more pics
Fred
Lars
ATX
Re: Wheels and brakes, what do u think?
« Reply #1 on: June 26, 2006, 08:25:51 PM »
Ooh, I like your color combo a lot! Wheels look good too.
« Reply #2 on: June 26, 2006, 08:27:01 PM »
looking good man
« Reply #3 on: June 26, 2006, 09:37:49 PM »
do you have stock rear wheel wells or is it mini tubbed??  what is the back space on the rear wheels??
dartracer
Strasburg CO.
« Reply #4 on: June 26, 2006, 11:31:02 PM »
Wheels look real good on that car.  Dave
mopar stu
« Reply #5 on: June 26, 2006, 11:40:29 PM »
i think it looks great, but you asked for my opinion and i think you could lower the front end a little,just enough so you cant see the tops of the tires.
« Reply #6 on: June 27, 2006, 12:30:33 AM »
Looks good Fred.  Last pic I saw of your care was in winter.  Your paint job looks even better in the sunshine, nice work.
Rate
If you got time to turn, you're going too slow.
« Reply #7 on: June 29, 2006, 06:19:15 PM »
Wow, that looks really good Smiley
plotners@msn.com
« Reply #8 on: June 29, 2006, 10:18:20 PM »
Lookin' real good Fred!    What offset do the wheels have and, if you lowered the front a little, would the tires rub??
Gettin' down to selecting wheel/tire combo for my car and am trying to research as much as possible.
Thanks Fred...
O.J.
My Mopars:
'69 Cuda SRT8 6.1 Hemi
'05 Jeep Grand Chickeree 4.7
"3 Hemis, no waiting!"
Tom1951
« Reply #9 on: June 29, 2006, 10:23:18 PM »
Looks sharp Fred       bbd sign
FredDart
« Reply #10 on: June 30, 2006, 09:25:57 AM »
The backspacing is 4 1/4''. I should have went with 4 1/2'' tough. The fit is really tight, especially in the rear, I can barely fit my fingers between the tire and fender. Nothing rubs, and I tried real hard to make them rub. The front passenger tire was rubbing, but that was because the LCA bumper was missing. I was able to lower the car a little more, about 3/4''. This is about the lowest I can go for now with my /6 t-bars. The spindles are from an 85 new yorker and the brake kit p/n is 140-2729. I had to replace the inner bearing, because the shaft is bigger on the new yorker spindle. My diff is an sure-grip 8 3/4, 3.23 gears with yukon axles and green bearings. Brake kit 140-5591. I had to machine the spacers for the caliper bracket to center the caliper with the rotor.
Fred
Dodgenut64
« Reply #11 on: June 30, 2006, 11:43:44 AM »
 nice man. i want 17x8s in the rear for my 64, but i want to go with 17x7s up front. so i guess you had more room to go back (in towards) the springs or would it be close there as well? do you think your tire would rub if you lowered your car in the rear? i want a modest 1" or 2" drop for my 64, but dont want anything to rub.
FredDart
« Reply #12 on: June 30, 2006, 11:52:42 AM »
theres plenty of room between the tire and springs, almost 2''. I dont think they would rub if you center the tire in the wheel well. I dunno if a 64 wheel well is different from my 68 tough. Measure at least 3 times before you order your mags, I was lucky mine fit, I messed up with backspacing while swapping brakes on 4 corners and changing diff with aftermarket axles... And a 17x7 is a better fit for the front, especially if you want to lower the car. I wanted a wider track and better handling, thats why I went with the 17x8, plus my mags are all the same on 4 corners. The handling is amazing with 225/45 and 245/17, pretty much neutral.
Fred
« Reply #13 on: June 30, 2006, 12:46:48 PM »
so the rears are 17X8 with a 4 1/4 back space...  and you recomend a 4 1/2 back space... right?    your not mini tubbed are you?  i have been looking for 17" rims for my 71 so this helps me out alot..
FredDart
« Reply #14 on: June 30, 2006, 12:49:47 PM »
Springs in stock location and not mini-tubbed. 4 3/4 would be a better backspacing.
Fred
dangerdawg
« Reply #15 on: June 30, 2006, 12:56:00 PM »
man, that looks pretty darn sharp!!!
« Reply #16 on: June 30, 2006, 04:17:36 PM »
Fred
  cool thanks...  i didn't think that much BS would fit...  that is definatley good to know..
« Reply #17 on: July 02, 2006, 11:17:13 AM »
I like the two tone also. I bet it gets alot of looks.
« Reply #18 on: July 02, 2006, 11:21:36 AM »
The car look great. Keep it up young man.
« Reply #19 on: July 02, 2006, 03:20:34 PM »
wow man that looks great, those rims are nice but they must have cost you a fortune, i think im going to go with 17s on my 72 duster, my plans are a 315/35r17 bfgoorich kd on the back with a 17x11 rim and 225/40r17 bfgoodrich kdw on the front
FredDart
« Reply #20 on: July 02, 2006, 08:55:11 PM »
The rims were 250$ US each. About the same price as Torque thrust 2, plus theyre costum built. Took 5 weeks to receive them.
I bought them from newstalgiawheel.com. Awesome price and service. They called me 20 minutes after I placed my order to confirm size and everything.
If you go 17x10, theyre priced at 275$
Fred
Dodgenut64
« Reply #21 on: July 04, 2006, 12:07:46 PM »
 this is the ride height i want on this 66 (mines a 64). thanks for the info. does anyone know the differances in the rear wheelwells of early As and 67- and ups?
Dodgenut64
« Reply #22 on: July 09, 2006, 11:09:00 PM »
hey FredDart can you take a pic of your car from the back? id really like to see how wide your tire combo looks. also how about some other pics of your car, gotta show off your baby. thanks
Cudadust
« Reply #23 on: July 10, 2006, 11:01:19 AM »
Thats an awsome combination, subtle but aggressive at the same time.  The stance is correct for factory settings with tires of equal size. To get the look thats recommended by some of the posts I run 215X60X15 on the front and 235X60X15 on the rear, this equates to 24.7" diameter front and 26.1" rear.
« Reply #24 on: July 12, 2006, 07:24:33 PM »
Fred
My custom TTHIIs were 300ish for the 17x11 with 5.5 backspacing.  I have nitto rubber on mine, newstalgia is a great place to work with, I used them too.  Backs are 315s currently, but have tons of room to go bigger.
