December 02, 2008, 10:28:57 PM
| | |-+  Cal-tracs and relocated springs
Author Topic: Cal-tracs and relocated springs  (Read 724 times)
mopowers
« on: June 28, 2006, 11:19:15 AM »
Is it okay to notch the spring box of a relocated spring to use with cal-tracs?  I noticed in the tech article about wideing a wheel opening, there was a picture with a notch cut out of the frame box.  Is there anyone here that has cal-tracs with relocated springs that can share what they did?  I was just concerned if that would weeken the frame at all.  Thanks.
2006 Dakota
drew54
Keokuk, IA
Re: Cal-tracs and relocated springs
« Reply #1 on: June 28, 2006, 03:25:16 PM »
I just relocated my springs w/the mopar kit and installed caltracs.  I didn't have to notch anything.  caltracs fit nice and tight in the spring box.  About the only thing I haven't had problems with Wink
Drew
68 Dart Post-572 KB-Stage V Hemi
http://www.myspace.com/154215108
mopowers
« Reply #2 on: June 28, 2006, 03:55:45 PM »
Hey Drew, you don't happen to have any pictures of the front pivot plate installed do you?  I'm making the cal-tracs and spring boxes by hand, so I'm just fishing for ideas.  Thanks man
2006 Dakota
drew54
Keokuk, IA
« Reply #3 on: June 28, 2006, 05:54:59 PM »
I'll go out tonight and get a pic, I'm working on installing sliders anyway.
Drew
drew54
Keokuk, IA
« Reply #4 on: June 28, 2006, 11:37:58 PM »
Here are a few pics, hope it helps.
Drew
mopowers
« Reply #5 on: June 29, 2006, 12:05:34 AM »
Hey thanks a lot Drew!  I'm going to make my own cal-tracs, so I was trying to get this figured out before I get started this weekend.  Did you make those relocation boxes yourself?  Does the bolt on the pressure point of the spring have a full size nut and head on the bolt, or are they slim?  I'm thinking I can grind down the head on the nut and bolt a bit for clearence.  And maybe widen the box a smidge and use washers for spacers on the pivot plate.  Thanks again man, now you really got me thinking.
-Evan
2006 Dakota
drew54
Keokuk, IA
« Reply #6 on: June 29, 2006, 12:16:29 AM »
Glad it helps, I just used the mopar boxes and added another 1/8" plate to reinforce the wholes, I also used a grade 9 bolt, think it was a 5/8 bolt, anyways it was bigger than the stock one and fit pretty tight in the holes I drilled.  I don't remember there being a bolt on the pressure point, I think it was just part of the pivot plate.  The mopar boxes are pretty wide and the caltracs had a bushing that fit tight from side to side in the box that went throught the leaf eye and then the bolt held it in place.  Also, there was a washer on the sides of the bushing to keep it all tight.  Good luck and post some pics when you're done.
Drew
bentwheel43
« Reply #7 on: June 29, 2006, 12:22:41 AM »
Drew
Hey drew, I am a AWS-CWI and I look at welds all the time,that wire that you used mite crack so keep an eye on it. I don't like that kind of welding wire for that job.  Tongue  Did you weld it down hill  ? Evil  I think I seen where you stopped at the bottom but in some places it looks to be uphill.   Embarrassed  That wire needs to be welded uphill.   YOUR FRIEND,  MAX43
mopowers
« Reply #8 on: June 29, 2006, 12:36:00 AM »
Max, can you explain the uphill welding technique briefly for me.  Tom did before, but I need a little refresher.  Is it where you start at the bottom and work toward the top angling upward?  How can you tell what welding wire was used?  And what kind was it?
Also, Drew, on the pivot plates, is there just a spacer connecting thet two plates that puts the presure in the spring?  I may just do that.
2006 Dakota
drew54
Keokuk, IA
« Reply #9 on: June 29, 2006, 01:14:09 AM »
The whole pivot plate was one piece so it all came together.
Max-thanks for noticing that, I think .30 wire was used, but it was just to fill the gap that was left to keep crap out of the open frame rail.  I plan on using 1/8 plate to attach the box to the back, welded uphill.  What size wire do you recomment for the job?
Drew
bentwheel43
« Reply #10 on: June 29, 2006, 02:01:24 AM »
All fluxcore wire needs to be welded uphill( gas or non gas) it will trap junk and not be solid, and thats just one thing. The heat raises and that helps the cleaning action of the weld.    Roll Eyes  With downhill welding will just lay on top,instead of going in to make it 100%   That steel looks to be .125 or 10ga. thats not very much it needs to be weld solid.    There just a few kinds of welds that are OK to be welded downhill high pressure pipelines with E7010 which gose deep,thin stuff like car bodys (hard wire not flux core).      getting back to that weld I think a E6011 would be better than that non gas fluxcore wire even if its uphill on those parts,but just keep an eye on it. I just had to say something  if I thought that someone could get hurt. I didn't say it because the weld looks bad that wire is the problem.  Roll Eyes  it also could have been welded with AC7018 by the way it looks, thats has to be welded uphill bottom to top or trap junk.
bentwheel43
« Reply #11 on: June 29, 2006, 02:33:19 AM »
Drew
If you use gas(75/25) use .023"hard wire or 3/32" or 1/8" E6011    Evil that was .030" non gas fluxcore wire.
Blue
« Reply #12 on: June 29, 2006, 02:58:38 AM »
Relocated my superstock springs years ago, picked up a good deal on a used set of Caltracs and mono's, unfortunatly they are a tad wider at the front bush so I need to widen the box a touch. Afco sliders designed for Chrysler springs don't fit either, the mono's have a much larger rear eye, the sliders need widening and making taller. Bet the pinion angle ends up wrong as well so the whole job can wait till the winter, can't waste good weather in England, it's not like we get much of it...
AdamR
« Reply #13 on: June 29, 2006, 07:13:43 AM »
Calvert has a new set of bars made just for vars with relocated springs so they fit in the box now. No more notching for clearance.
www.forabodiesonly.com
Forums and classifieds
Crazy68Dart
« Reply #14 on: June 29, 2006, 04:26:22 PM »
I had a few problems with my setup, but got it all figured out.  The major one was the Caltrac bracket was not welded accurately and caused binding issues.  They sent me a new one next day, so I cannot complain, good guys to deal with.
drew54
Keokuk, IA
« Reply #15 on: June 29, 2006, 08:06:33 PM »
I just installed a set of Afco sliders from Bill and they work great w/caltracs and monos.  Just had to use the regular bushing instead of the smaller chrysler one.  That's strange yours didn't fit Huh
Drew
vitamindart
« Reply #16 on: June 30, 2006, 12:13:59 AM »
yep me also got sliders and smaller bushings from bill fit great, can't wait to try them out  Grin Grin
Blue
« Reply #17 on: June 30, 2006, 02:07:06 AM »
Damn! My mono's have a huge 2" rear spring eye, must have changed the design, mine are about 5 years old.
