Topic: Six-Pack fast idle solenoid wiring and mech. choke questions? (Read 346 times)
69 GTS Clonvertible
Ok, I purchased a fast idle solenoid from a guy off of Moparts, by the name of Jim, Now I need to know before I wire it up, how should the solenoid be powered? I have a wire that I believe was to the old 4 barrel electric choke. When the key is off there is no power to it, but when I turn the ignition switch to the on position it has power, I haven't checked to see if it has power durring start up or while the engine is running, but I would think it has power while the engine is running, because the wire is hot when the key is in the on position. Also should the mechanical choke be connected while the fast idle solenoid is bolted on and working? If so should the choke blades be completely shut while not running?  Shawn
qkcuda
As long as you have power when the key is on that wire should work.
