October 15, 2008, 08:02:12 PM
| | |-+  17 inch wheels ?
Author Topic: 17 inch wheels ?  (Read 1071 times)
blown71duster
17 inch wheels ?
« on: June 30, 2006, 02:23:11 PM »
Does anyone run 17's ? I have a 71 duster that I want to put them on, but having trouble finding a suitable tire for the rear . I would like to find something that will fill the wheelhouse . It has the springs moved in to the frame and would like to find something about 28" tall and with a sectional width of 11.5-12.5 can"t seem to find a tire with those specs in 17 rim. I really want to nail a lower  mean stance with decent meats,  Thanks
1971 Duster 440  Single turbo
kowski71400
Re: 17 inch wheels ?
« Reply #1 on: July 01, 2006, 05:29:52 PM »
if you go on to tirerack.com, you can shop for tires by size. just pick a size you think might fit and do a search. when the search comes up, hit SPECKS and it will bring upthe specks on all the tires in thet cat. it gives you the size, section with, ext. for the different tire sizes. hope this helps
nd2stopfastr
« Reply #2 on: July 24, 2006, 10:28:53 PM »
275/50     28"x11" most street cars dont use 28" tires, you might need to look at a suv/st tire
blown71duster
« Reply #3 on: July 25, 2006, 06:06:33 PM »
I am wanting to put a taller tire on my duster I am going for a look like this nova I found a picture of , I like the look, kinda a cross between pro street and pro touring,modern wheels , thanks
Evan
Fayetteville, Arkansas
bigjohncat
« Reply #4 on: July 25, 2006, 06:27:57 PM »
its getting easier and easier to find tires for 17s. 325/40/17 is a common size and should be more than wide enough. just look in summit or jegs or tirerack.com
jmgilkins
« Reply #5 on: August 01, 2006, 10:28:40 PM »
You can also check out www.mandhtire.com, nitto tires and goodyear drag radials for 17in gripping tires. 4 speed
Bill_Reilly
Administrator
White Haven, PA
« Reply #6 on: August 01, 2006, 11:42:17 PM »
I can vouch for the Nitto NT450's and the NT 555's.  The 555's feel similar to my old M/T Pros I had previously - fairly sticky once they warm up. I put the 450's on my dart in the hopes of a little longer life. Playing with the 555's on a hemi cuda, it's obvious to me they won't last very long the way we typically drive.
blown71duster
« Reply #7 on: August 02, 2006, 06:31:19 PM »
Thanks guys I'll check them out.. Kevin
