Topic: POR15 (Read 816 times)
Darren
POR15
« on: January 08, 2006, 10:00:13 PM » |
Is the por15 stuff good for brushing on the underside of my car and on the floor and trunk pans inside the car, And how should I prep the metal before brushing it on.And also does it stop rust from spreading? Thanks.
azz7772
Re: POR15
« Reply #1 on: January 08, 2006, 10:19:45 PM » |
ya you can brush it on. I would sandblast but if you do not have than a wire wheel on a side grinder then sand untill your satisfied. but to me it sounds as though you have some surface rust i would sandblast it off even if you have to rent a sandblaster for a weekend.
Darren
Re: POR15
« Reply #2 on: January 08, 2006, 10:27:38 PM » |
I just have a bit of surface rust in the common spots ( frame rails, trunk and floor pans) places like that, I was reading on there website and it says that it stops rust and even fills pin holes, just wondering if it is true ? thanks
Re: POR15
« Reply #3 on: January 08, 2006, 11:20:57 PM » |
Like azz7772 said I would try and remove the surface rust i.e. 4 1/2" wire wheel on an angle grinder. You would have to be able to get to both sides of the surface to seal it from spreading. I brushed it on the RR and you can't tell it was brushed. Forms a very hard plastic like coating. I plan on doing the same with the Dart. Also the sealer is not UV friendly.
Tom
 The Green Dragon, Terminator and Birdius Rapidus
Re: POR15
« Reply #4 on: January 09, 2006, 08:01:50 AM » |
Just like paint prep is key.
Cary Snyder 5.7L Hemi Cuda
FredDart
Re: POR15
« Reply #5 on: January 09, 2006, 05:04:34 PM » |
I suggest you use their MetalReady for prepping surface. Its basically phosphoric acid and zinc. After a couple minutes, the acid etches the metal and the zinc bonds to the metal. Just rince off to neutralize. Worked great on my floor pan
Fred
Crazy68Dart
Re: POR15
« Reply #6 on: January 09, 2006, 09:34:08 PM » |
I used Ospho to treat any marginal spots and a 4.5" cup wheel. Brushed on the Por15 and then top coated with Rustoleum Semi-flat black. Looks nice.
Andy
