December 02, 2008, 10:20:26 PM
| | |-+  Manual trans steering column ?
Author Topic: Manual trans steering column ?  (Read 300 times)
dusterdemon
« on: July 02, 2006, 08:25:28 AM »
Is there a simple way to tell a power steering column from a manual steering? Thanks Warren
abodyjoe
South Jersey...
abodyjoe
Re: Manual trans steering column ?
« Reply #1 on: July 02, 2006, 08:54:10 AM »
the manual is longer but if you don't have the other one to compare it to it may be hard to tell...    it really doesn't matter though..   the main shafts interchange in the columns..  so you can make what you need pretty easy..
GON_RACIN
Happiness is a warm gun.
« Reply #2 on: July 02, 2006, 11:01:43 AM »
the spline count on the inside of the coupler is different aswell, so if your converting over but SURE and get the manual coupler too so the neighbors dont have to listen to your profanity when you go install the column and it wont mate up to the steering box     go on, ask me how i know  Tongue
