Topic: Neutral safety switch (Read 369 times)
RR_Sweden
Hi anyone who knows how to wire the three pin connector on a 727? Ingemar
RR_Sweden
Well it has three pins and I know that they are for backup light and starter but I dont know wich wire that is for starter and light
mopar stu
the one for the starter goes to the solenoid and has a rectangle plug on the other end,i think it is brown with a yellow stripe,what colors are there?
RR_Sweden
I dont know I dont have the harness. Is that one ground for the starter relay?
mopar stu
yes the one to the solenoid is the ground,it is the connector in the middle,it goes to the G on the solenoid
RR_Sweden
Ok thanks so its the one in the middle. And the outer two is for the backup-light?
mopar stu
thats correct at least on a 72',but i'm pretty sure they are all the same.
RR_Sweden
Yes mine is a 68 but as you say I am building from scratch Thank you. Ingemar
Michael Deakin
With all due respect Cudadust, when you are outside of the US, someone like Evans are not easy to deal with, cheaply. i bought a new neutral safety harness from Evans but he does not take paypal or credit cards, so the only other alternative was send a bankers draft , which, speaking from experience, is very expensive and time consuming due to the USPS. Fortunately, i managed to get round this by paypaling Jim lusk the money and he very kindly sorted everything at the US end Sorry Jim, if you did not want me to divulge this. Mike
Dart 440 GTS, 11.09 121.31 mph 1.66 60ft
