December 02, 2008, 11:06:23 PM
| | |-+  manual steering box questions
Author Topic: manual steering box questions  (Read 313 times)
fishhead
« on: July 04, 2006, 03:09:54 PM »
hey all,  I want to dump the power steering  unit in my 67 cuda and stick in a manual setup.
      three questions I have:
        1) the manual box i have is from  a  1965 (v8) barracuda.  will that fit  a 67 cuda
        2) what about the pitman arm? would the arm attached to the 65 box be correct for  a 67 cuda
        3) I know aboput the little adapters available to correct the steering column length, but what if i had a steering column shaft from a manual car, couldnt i slip that inside my my power column thats in the car now.  or would that not work? what if the   donor shaft was from a column shift  manual car??
   thanks in advance,
  neal
55robert@comcast.net
Re: manual steering box questions
« Reply #1 on: July 04, 2006, 04:51:02 PM »
it will bolt right in but you'll have to compare the steering arms to each other. the manual shaft will work. manual or auto, it doesn't make any difference.
