Topic: two batteries question (Read 297 times)
Michael Deakin
I am getting a misfire at the top end of the track and i think the battery is not coping well enough, so i'm thinking of fitting a second one on the other side of the trunk. The car has a dual field alternater, Gold box and the stock ballast, could this cause the misfire, i have read the gold box needs a 0.25 ma ballast and the stock one is 0.50. Mike
Dart 440 GTS, 11.09 121.31 mph 1.66 60ft
2 things. first get the correct ballast. second check the firewall connectors to be clean especially the main feed to the coil. use spray contact cleaner.
Michael Deakin
It never happens in the first 2 gears, it's always in 3rd. Bob, 2 of the firewall connectors are new and 1 is the engine bay, coil is accel super coil. I am fitting a new battery brfore it hits the track again, i will check all the connections again. The alternator is dual field. I have got a spare orange box, i may try that next time out, as i know they use the .5 ma ballast. Thanx for your input Mike
