Topic: Master cylinder leaking around lid. (Read 314 times)
5258
My strictly drag race duster runs with all manual brakes, as of late the matser cylinder is leaking around the lid after each pass (enough to grease up the firewall). I'm running the old metal lid type cylinder. A couple of questions I have is 1) the pedal is soft and sometimes requires to be pumped up, could the leak around the lid be causing this problem? Brakes have been bleed numerous times. 2) I'm running A-body hooker fenderwells so Im worried if i go to a newer master cylinder with a plastic tank and screw on lids the heat from the headers (2-4 inches away) will melt the tank. Does anyone have any advise?
5258 Performance Shelbyville, Tennessee "Where the MOPAR factory built and race ready hotrods live again"
Dartsport
I have a heat shield between the headers and the master cylinder. About 2" to 3" between the headers and mastercylinder.
Ed
Check to see if it's leaking inside the car, up under the pedals. If you have to pump the brakes, it might be wore out or the brakes (drums) need adjusting
formerly VIN_VL29U
mjudd
....... I'm running A-body hooker fenderwells so Im worried if i go to a newer master cylinder with a plastic tank and screw on lids the heat from the headers (2-4 inches away) will melt the tank....
I use Hookers and have the newer master cylinder...no problems at all. be sure to use a heat shield too that's some leak, there's a lot of brake fluid on your driveway
Tom1951
"73 Dart Sport, 11.5 to 1, 446, Racer Brown STX20, Eddy's, M1 single plane, 850 Mighty Demon, TTI's and soon to be installed a AlterKation... ô¿ô
cu440da
'67 Notchback- 12.85 @ 109mph
