November 22, 2008, 08:08:09 AM
| | |-+  Master cylinder leaking around lid.
Author Topic: Master cylinder leaking around lid.  (Read 326 times)
5258
bigblockdart.com
« on: July 10, 2006, 07:06:06 PM »
My strictly drag race duster runs with all manual brakes, as of late the matser cylinder is leaking around the lid after each pass (enough to grease up the firewall).  I'm running the old metal lid type cylinder.  A couple of questions I have is 1) the pedal is soft and sometimes requires to be pumped up, could the leak around the lid be causing this problem? Brakes have been bleed numerous times. 2) I'm running A-body hooker fenderwells so Im worried if i go to a newer master cylinder with a plastic tank and screw on lids the heat from the headers (2-4 inches away) will melt the tank.  Does anyone have any advise?
Dartsport
Re: Master cylinder leaking around lid.
« Reply #1 on: July 10, 2006, 07:20:39 PM »
I have a heat shield between the headers and the master cylinder. About 2" to  3" between the headers and mastercylinder.
Ed
Phoenix, Az
« Reply #2 on: July 11, 2006, 02:44:25 AM »
Check to see if it's leaking inside the car, up under the pedals.   If you have to pump the brakes, it might be wore out or the brakes (drums) need adjusting
formerly VIN_VL29U
mjudd
Springfield, Il.
« Reply #3 on: July 11, 2006, 07:37:48 AM »
....... I'm running A-body hooker fenderwells so Im worried if i go to a newer master cylinder with a plastic tank and screw on lids the heat from the headers (2-4 inches away) will melt the tank....
I use Hookers and have the newer master cylinder...no problems at all. be sure to use a heat shield too
that's some leak, there's a lot of brake fluid on your driveway lol bash   Roll Eyes
Tom1951
« Reply #4 on: July 11, 2006, 01:40:03 PM »
The master cylinder heat shield is available thur www.4secondsflat.com
"73 Dart Sport, 11.5 to 1, 446, Racer Brown STX20, Eddy's, M1 single plane, 850 Mighty Demon, TTI's and soon to be installed a AlterKation...   ô¿ô
Saint Paul, MN
« Reply #5 on: July 12, 2006, 12:58:09 AM »
I don't care who ya are, that there's funny!! lol bash lol bash
'67 Notchback- 12.85 @ 109mph
