Topic: What is Everyone Working On? Volume 2 (Read 12288 times)
spikekid999
MOPAR OR NO CAR!!
i know not many (if any) will like my projects, but i do (and thats all that counts right?) right now im workin on my 87 5th ave. doin some fab work in the trunk for the hydro setup. 4 batteries and 2 pumps. i added frame connectors and changed out the rubber iso mounts up front for solid aluminum ones.   after i get the hydros installed in the 5th ill turn my attention to my other project, my 74 dart sport. workin on getting a BANGIN stereo in it, ill clean the underside,install frame connectors,and undercoat it. i already changed the 7.25 rear for a 8.25 and changed the front rotors to the 4.5" bolt pattern (all so i could put my rims on it  ) when im done itll have a flacked out green paint job with black patterns, matchin flaked green rear end,gas tank, tranny,motor,and driveshaft, and LOTS of chrome. oh ya and this puppy only has 44xxx on the clock and has all original hoses under hood and all original interior (except for the wheel i swaped out)    this will also get hydros in the future you can see more pics of both rides in my sig.
Womanator
Started work on the next project today./6 car with 4-speed overdrive. 74 Plymoth Scamp  Manuel steering power disc brakes and a 4-speed car just pulled the engine
Bigcube
I installed new door panels on sat   Back one needed a little trim   Yesterday I got the dash in.
Jim  Yes it's fast and no you can't drive it! Best 1/8 1.259 60', 5.67@121 Best 1/4 8.94@151 All Motor http://www.bigcube.org/
FastmOp
Looks good big Cube and spikekid. I had a couple low riders with Juice when i was a pup. One was a Gutless, it only had front, and I thought the 12's were thumpin till I built the S-10 with FBSS and two 12's, a 10" bazooka, and two 15" orions in the the bed for cruzN. Yep, i still like em but there hopping just aint as fun as the Valiants launch hanging the hoops about a foot for 60'  Heres a new pic of the Avenger, been plugging away when i can, it's close to rolling.
spikekid999
MOPAR OR NO CAR!!
thanks fastmop. both my cars are gonna be clean cruzers. id like to hop em but with the unibody im afraid of wreckin it,even with frame connectors. but ill still do the 3 wheel  the 5th only has a pair of 10s since thats the biggest i can fit,but there good enough for me. i got a pair of 1000watt 10s for the dart, but my amp $h!t out on me right away, so i gotta send it back for a replacement, just aint got a box big enough to ship it
MyCreation68
I got my SS/T on the road today. And by that I mean I washed and waxed it and did a complete detailing. it looks great.
today abrasive came over and we redid the inter fender wells to keep the slicks from rubbing them. they came out good. we also raised the back of the hotrod up 1" so we are good to go now and with just a tad more body work on the front of the wheel well lip and paint it.
496dart
Installing a Dana 60 and moving in my springs. Taking way longer than expected . I think most of that time is fabbing--fitting , cutting , grinding.... We are 8 hours in, only to find out i have the wrong ring gear. Did you know there are different thickness ring gears for Dana 's ? I sure in the F didnt.  the guys helping me have some SERIOUS badass race cars in the shop---one is a low 8 sec Duster .........i will post pics after i get some sleep.
i have a new spacer and bolts to install a higher gear in a 4.56 dana carrier if you need it.
dart4406
Painting My Basic Pit Area Transportation...The Golf Cart!
Home Of Bill Stiles Performance--Jere Stahl Headers And Dave Strickler--"The Old Reliable"
496dart
thanks bob-- turns out the gears were 4:56 - not 410 like i want. we found a 410 set , but i have to get a fine spline yoke monday . "should " have the car done monday night sans driveshaft . I will have a factory width A body 8 -3/4 housing , Yukon axles , 742 center section , for sale in a couple days if anyone is looking for that stuff. I will list the parts on the "other" mopar site that has a for sale section.....
Bigcube
I've been doing a bit of wiring. Crank trigger, throttle switch and under hood wiring of the solenoids still needs to be done. I got to get the motor/tranny in today.
golferjohn
painted my house  need to finish hanging the cabinets and crown this week  completed the center caps and installed them  moving in a couple of weeks...haven't done that task in 13 years
Capt Jack
as they say, practice makes..........insanity ![\/][](http://www.bigblockdart.com/Smileys/classic/finger020.gif) just finished a few minor interior details on the duster. finally have a gauge package and dash insert so I can lose the 80% non-functional stock instrument cluster and replace it with a nice custom package I snagged at the last good guys show (and proceeded to misplace...until this past weekend)  2 engines in work for relatively (initially) stock rebuilds. a mid 80's era motorhome 440 (TBD where it ends up) and a formerly truck 360 (possibly for the Coronet). now I just need the  to pay for em.
DusterDave
Just finished painting my Duster black, so I'm doing the cut'n buff routine on it. Once that is complete, I can attack the short list. - Install polyurethane LCA bushings - Paint LCA's, steering box, an A-arms metallic silver - Replace front windshield - Buy & install new door weatherstripping - Install new oil pump - Replace burnt pushrod - Buy new starter - Install new set of valvesprings - Install motor & trans -Install headers - Install K frame and front suspension - Clean up interior and trunk - Reconnect all wiring and hoses, etc - Fire up engine - Get front end alignment - Show off new paint job!
Hawkeye
I've got a 71 dart I'm working on. The car is stripped down and on the rotisary, working on the front suspension, rear suspension and the 383 BB is in the other side of the shop getting the bottom end put together. Retirement is great, I just need to keep the motivation up and the money coming in, these things are expensive! Wes
rarefish
Just got an estimate on the body work on my 68 Cuda convert. Once I get my daughter settled in school I hope to send it off. don't know which one will end up costing more, Joe.
KEEP THE FAITH 56 Zodiac 66 Fury III convert 68 Formula S 383 4spd convert 85 Ram Charger 96 Ram Jayco conversion
qkcuda
Well, I am finally finished working on the house and back to thinking about the car. I am getting parts ready for the big thrash on the August long weekend. I have to have this thing running again for Moparfest. I port matched the Torker intake, refinished the new coil bracket to clear the Holley, and ordered some 3/8 line to re plumb the fuel system. I'm trying to have everything ready to just bolt on when I finish the cam swap.
OMG! Is this thread still alive?
Bigcube
I got the motor in yesterday... Don't ever try to move plumbing around without the motor in the car  I needed to move the lines from the pump to the pan to make room for a temp sending unit. I lowered the hose's a little and they hit the column  I re-plumbed them today  Looks like I got a bit more plumbing to do   I have to re-do all the fuel lines to add another regulator.. things are going to look a little busy with all the fuel lines are run.
I got the motor in yesterday... Don't ever try to move plumbing around without the motor in the car  I needed to move the lines from the pump to the pan to make room for a temp sending unit. I lowered the hose's a little and they hit the column  I re-plumbed them today  Looks like I got a bit more plumbing to do   I have to re-do all the fuel lines to add another regulator.. things are going to look a little busy with all the fuel lines are run. wow jim when you decided to go nos you picked out a real nice kit for sure.
Bigcube
Hood clearance is a bit of a problem so no room for a plate. Besides, foggers just look so damn cool
I managed to work on my hood project today. For those who do not know I bought a pile of shit WS Racing hood. Anyway I removed it from the frame they sent it on. Then removed the skin from my original hood. I have now sand blasted it and POR15 the in side of it. Come next week I will bond it together. I have several pictures on my Photobucket page. Here is a link http://s301.photobucket.com/albums/nn47/Bakaruda/
Cary Snyder 5.7L Hemi Cuda
GTS Cowboy
Slideshow is cool. Your car is gourgess Cary...real nice work, very tasteful ! Now we just need some video
 Life begins @ W.O.T.
