December 04, 2008, 05:02:55 PM
|-+  General Category
| |-+  Off-Topic
| | |-+  What is Everyone Working On? Volume 2
Pages: 1 ... 12 13 [14] 15 Go Down Print
Author Topic: What is Everyone Working On? Volume 2  (Read 14836 times)
Ft. Worth TX.
Re: What is Everyone Working On? Volume 2
« Reply #390 on: August 25, 2008, 07:18:52 PM »
I wish I knew what happend with Mike.
Cary Snyder
5.7L Hemi Cuda
Megajoltman
« Reply #391 on: August 25, 2008, 08:08:38 PM »
Well after being in the Hospital for 2 months and told I won't be allive in 6 months I 'm out feeling much better and put new rear  lift leafs in my Ram to level it with the front.
building a 69 383 dart
Daily Driver 1998 Ram CTD 12V 4x4 Quad Cab Auto Shortbox, 3in Carli lift with custom rear lift springs (no factory blocks anymore) DSS Steering Stabilizer, 315 Toyo Open Country M/T tires
CudaDon65
« Reply #392 on: August 26, 2008, 10:33:10 AM »
This is some work I've done the last two weeks.. duster
CudaDon65
« Reply #393 on: August 26, 2008, 10:34:29 AM »
Some more. throw money
sycboi
Norwalk, Ohio
bgpoppahall sycboi bgpoppahall
« Reply #394 on: August 26, 2008, 01:25:12 PM »
Did those vents fit right in there like that?  I have an A-10 dash as well.
I bought the Hot Rod Air brushed aluminum directional vain vents and there is no way in hell they will fit the dash holes.  Maybe I could machine some of the outer perimeter off to make them go, but I would hate to have them fall apart on me if I took too much aluminum away.
-Michael
SuperBeast
'70 Dart
Roller 383 w/ much aluminum
Viper T-56, StreetTwin, hydraulic throwout, HD Dana 60, AlterKtion
An enforcer for the Mopar Mafia!
Ft. Worth TX.
« Reply #395 on: August 26, 2008, 02:22:05 PM »
Michael, PM me your # they fit just fine. I will tell you what you have to do.
Cary Snyder
5.7L Hemi Cuda
Ryan (Strange246)
Merrimack NH
strange246 strange2462000
« Reply #396 on: September 01, 2008, 08:31:35 PM »
Finally a day with some car work! I put her up on the lift and pulled the tranny, swapped the flexplate, put the tranny back in the car...Tomorrow I'll be installing the fuel system, pump, filter, lines etc. and hopefully get the radiator mounted...
duster
Ryan
Dr. Hunter S. Thompson
Bigcube
Get in, sit down, shut up and hang on
« Reply #397 on: September 03, 2008, 10:54:50 PM »
Well... good news and bad news.  I warmed it up sat, ran the valves and pulled it out to wash it.
Well that's where the good news stops.  I started it up to put back in the garage and it quit, no spark  So I tested the pickup, it seems to be working but the coil test's like it's shorted.  I ordered a new one and it should be here tomorrow.  Undecided I still hope to beat the crap out of the car on fri for putting me though this
4 speed drag tree 4 speed
Jim
Yes it's fast and no you can't drive it!
Best 1/8 1.259 60', 5.67@121
Best 1/4 8.94@151 All Motor
http://www.bigcube.org/
BrianT
It's 1978 all over again!!
« Reply #398 on: October 01, 2008, 08:26:31 PM »
Got a little progress done on my interior project today.  My son and I installed the recovered back seat and started fitting the new carpet set!
67 Dart 340
"Doing everything ass backwards"
DusterDave
« Reply #399 on: October 03, 2008, 06:19:10 PM »
Just finished painting my Duster black, so I'm doing the cut'n buff routine on it.  Once that is complete, I can attack the short list.
- Install polyurethane LCA bushings - DONE
- Paint LCA's, steering box, an A-arms metallic silver - DONE
- Replace front windshield - DONE
- Buy & install new door weatherstripping - DONE
- Install new oil pump - DONE
- Replace burnt pushrod - DONE
- Buy new starter - DONE
- Install new set of valvesprings - Decided not to do
- Install motor & trans -DONE
-Install headers - DONE
- Install K frame and front suspension - DONE
- Clean up interior and trunk
- Reconnect all wiring and hoses, etc
- Fire up engine
- Get front end alignment
- Show off new paint job! !nanr
Click http://hemiduster.com/black_paint.htm for latest pics.
9.16 at 147.6
www.hemiduster.com
DustMan
« Reply #400 on: October 03, 2008, 07:23:52 PM »
Working on my first ground up build. Finished my chop a while back.
Yep, thats an 8 3/4 Rear. Now its about finishing up the Chassis...
And being able to use my Pineapple Grenade as a shifter
Here are my Grill choices. I'm thinking the black and silver 32 one, whatcha' think?
Been a few months of work, but this will be one nasty hot rod pick up. I think she will weigh in around 1800lbs
The enemy of performance is weight
rjsjea
ProTouring Demon
« Reply #401 on: October 03, 2008, 09:21:18 PM »
A chop is pretty daunting........all flat glass I suppose in that hot rod, makes it a little easier.  Looks good
DustMan
« Reply #402 on: October 04, 2008, 12:48:20 PM »
Thanks man, yeah the chop was a challenge, not because of the chop itself but because I raked the windshield back Bonneville style.
A regular chop would have taken me a week, the raked windshield chop took 3 months. Its chopped 6.5", and yeah, the windshield will be 2 piece flat glass.
The next one I do will be much faster. You learn so much building a vehicle from scratch.
FastmOp
« Reply #403 on: October 04, 2008, 11:42:03 PM »
This is a ford I been building for a wile, we blew it up once in the driveway but now it's running again.
357ci Cleveland with Boss 302 heads and a 6-71, herbert roller, 5500 stall bla bla
Sorry for the ford post but I did drive it today for the 1st time ever. He hopes it outruns the Valaint. LOL
Ed
Phoenix, Az
« Reply #404 on: October 05, 2008, 12:42:55 PM »
working on a '71 454 4 speed vette, but only at night, don't tell anyone
formerly VIN_VL29U
CudaDon65
« Reply #405 on: October 05, 2008, 01:28:49 PM »
Working on the back seat...so far so good. !nanr
CudaDon65
« Reply #406 on: October 15, 2008, 12:30:13 PM »
I did some painting last weekend..first time I ever painted with a paint gun. The paint came out OK I think.
Its eastwoods quarter mile candy red, single stage urethane enamel and epoxy primer. Here are some pics. !nanr !nanr
CudaDon65
« Reply #407 on: October 15, 2008, 12:31:50 PM »
Here's more pics..
GTS Cowboy
« Reply #408 on: October 15, 2008, 12:44:15 PM »
Looks geat!! Cool
Life begins @ W.O.T.
DustMan
« Reply #409 on: October 15, 2008, 04:21:52 PM »
That does look great. Good job man!
satellite65
Long Island, NY
« Reply #410 on: October 15, 2008, 04:46:46 PM »
Hot color. What's that? candy tangerine?
CudaDon65
« Reply #411 on: October 15, 2008, 05:22:15 PM »
Thanks, it's a candy red but under all the lights and the flash of the camera it looks a little orange.
satellite65
Long Island, NY
« Reply #412 on: October 15, 2008, 05:47:04 PM »
Still smokin'. Can't wait to see it finished. (can't wait to see MINE finished either)
lake worth, florida
55robert@comcast.net
« Reply #413 on: October 16, 2008, 10:48:39 AM »
finally the light of day.
lake worth, florida
« Reply #414 on: October 16, 2008, 10:57:53 AM »
trial fit up on the trailer. me and abrasive modified the trailer so we wouldn't have to use boards on the ramps to load up. worked with plenty of clearance for the first time.  Cheers
GTS Cowboy
« Reply #415 on: October 16, 2008, 11:36:20 AM »
Let's hear that bitch run!!...YEEEHAAAA!!!
FastmOp
« Reply #416 on: October 16, 2008, 10:26:18 PM »
Congrats Bob on getting it that far.
I really hope someone gets vids, that thing is going to be bad ass. drag tree
smitty72
I'll finish it someday
« Reply #417 on: November 02, 2008, 07:25:45 PM »
making some progress on the beast, the 6 point roll bar is done. got the bar painted today. I will be putting the headliner in when I get the time nad the weather permits. after that I will get the carpet in  !nanr. make the wifee happy I will clear up some of my storage space.
golferjohn
« Reply #418 on: November 06, 2008, 06:31:17 PM »
It may not look like it, but we're moved-in and cozy.  Haven't moved for 13 years...what a pain!!
GTS Cowboy
« Reply #419 on: November 07, 2008, 07:47:05 AM »
Congrats...Nice looking place...do we get the tour? Popcorn
Pages: 1 ... 12 13 [14] 15 Go Up Print
