Topic: What is Everyone Working On? Volume 2 (Read 14927 times)
I am only missing 2 parts from my dash. The first is my A/C controler, then the stereo. I will buy it when the car is ready for the road.  This is the color I am thinking of going with. My rollbar will be done in the color, and all of my suspenion stuff.
jet-taz
real nice  is the fuel gage working with a stock tank or aftermarket?
I am using a aftermarket tank.
DustMan
I am taking a little break from the Duster to build one of these (mine isn't the one pictured below, but you get the picture).
I have to get it running for under $3000 to meet the challenge and I will definitely meet that goal at this point (I only have $150 invested so far!). I have the cab, motor, tranny, radiator, tires/rims, K member, electrical, and seats (that actually fit!). I have to pic up my 8 3/4, the front I beam suspension, fab the rear suspension, get the 2X3 metal for the chassis, gas tank, steering column, and some other small stuff.
It's crazy that you can build one of these for next to nothing when you know the right people.
I am painting it flat blood red.
The enemy of performance is weight
rharveysr
This is my son's 68 Prostreet Dart...that we will be back working on come October 1st.
Rick and Rickey Jr.
66sat440
i'm working on my 440 fuel injection manifold,old offy intake,fuel bungs and rails from ross and two dakota v-6 throttle bodys that i scored for ten bucks each!think i have about two hundred bucks into the whole setup so far. plan on getting the regulator next so i can plumb the fuel rails.then a set of #32 injectors to finish it off.i want to build the megasquirt controler this winter so i can try to have it running this comming spring. everyones gotta have a hobby!
thats gonna leave a mark!
FastmOp
Looks tough as hell!
66GG1TnC
<surfacing from deep lurk mode> Well it ain't an A-Body...but it's mine and it'll haul the whole family, both dogs, the 10 tons of crap required to support a wife and three kids away from home for more than an hour  . Well, it'll do all the above once I get it running!  Just put freshly painted Cop Steelies and 255-60-15's on to replace the original H-78-14 maypops. This winter when it's not so freakin HOT <118 in the shade, 102 at midnight> outside I plan on pulling the 383 4bbl and rebuilding it (it's stuck, got another good core if it's bad) Strokin it if the budget allows. I miss my A-body's....but I like my Sea-Body! More pics here http://www.picturetrail.com/gallery/view?username=64chrysler300&x=17&y=10
Rob
'66 Chrysler Town & Country '64 Chrysler 300 '47 Farmall H
70dart408
just a little body work going on
318_Magnum
I am only missing 2 parts from my dash. The first is my A/C controler, then the stereo. I will buy it when the car is ready for the road.  This is the color I am thinking of going with. My rollbar will be done in the color, and all of my suspenion stuff.  That's REAL nice man. What color is that?
xxxxx  xxxxx 72 Demon- 340/727/8-3/4 69 Barracuda Fastback- 400/727/D60 76 Dart Sport- 360/904/8-3/4 99 Dakota Sport- 318/NV3500 04 MazdaSpeed MX-5 Turbo- 6-Sp/MBC/Intake/TB Elbow/Comp I&O Pipes/DP/BOV/O2 Mod/FMIC/DTT & More
The dash is bare metal. I am thinking of powdercoating it Candy Blue. That is what the sample is.
i've been trying to fab up the throttle bracket. that went fairly easy until i welded the bracket for the retun springs. i didn't get it far enough down to put enough tension to close the throttle blades, not a good thing. so that was one of the things i didn't have to do once.
today i managed to get the throttle control hooked up and operating almost correctly, just have to mess with it a bit more to get the hesitaton out of it.
I bought an enclosed trailer and started tearing the shitty old cabinets out of it.  Now I have to put new cabinets in  And the ramp door needs some repair too. Needless to say, none of this  for a while...
good friend of mine in HS had one of those. it was THE drive in movie car! I think our record was 12 people in it at once. me, him, his brother and 9 girls. good times.....good times
rharveysr
Well..besides the 68 Dart of my son's ...this is our current project that is sitting in the driveway. Its a 99 Dodge Cummins Diesel that we have modified just a little. This picture shows the twin turbos that we installed. Mod's include a fully port and poilished 'O' ringed head with ARP head studs,150hp F1 injectors,F1 custom ground cam,hot rod VP44 injector pump,Edge Juice,and cant forget the NOS. Not shown in the picture is a set of custom built ladder bars that Rickey and I built..well lets say I cut and tacked it together and Rickey did all the welding. Estimated hp on motor only is low to mid 600 hp at the rear tires..and that would put the torque at around 1200lbs..Truck will be used as a daily driver. NO this is not our truck...it belongs to a customer and good friend of ours..Oh by the way...ignore the Banks Big Head logo on the wastegate...it is NOT a Banks Twin turbo kit....
Rick and Rickey Jr. DBA: R&& Racing Enterprises Inc
MikeR
The new dash is installed and works great!
Looks goods Mike.
badazzdart
-0*(trying to cut down on alchohol consumption so i can finish my dart
you cant stop what you cant catch!
chryco
houston we have a problem, no that's two problems houston. the #1 and #2 header hits the #3 main cross bolts. damnit jim, if it's not one thing it's another. oh well abrasive is modifiing them. hopefully enough to fit the diaper on too. i think it will work out with a little header wrap to keep it from melting.
speeddemon_09
Well, I WILL be working on my '70 Plymouth Duster in the near future Here it is in 2002   Here it is now Heres the 360 I want to put in it(gotta swap out the slant six k-member with the V8 k-member)    Here is the car as of now     Now, Im not a very active member on this board, but I would like to be, but Im always on another forum most of the time. Also, I am a junior in high school and going to a vocational school in auto mechanics. My instructor is a pure mopar nut(who knows, he might be registered on here). My instructor has a '70 duster with a 440 that he drag races, thats what I want to do woth this car in the future is put a 440 in it, but Im only in high school, so I cant afford a 440 yet. My dad has most of the parts to make this car road-worthy. He has new front fenders, a new quarter panal, a new k-member for the V8, and thats basically it. He has a 904 trans for it, I'll use that 'till I can get enough money to buy a 727 for it, then I can really have some fun with this car  Well, thats it, I hope to work on it this winter
Bl1zzard
Stripping, then sanding, then priming, then reassmbling, then painting, then  Hopefully...
sycboi
I punched a bunch of holes in the bottom of my air cleaner lid to help it breathe a little better...  Trying to get my homemade exhaust final installed. The tips are made by myself as well and a bitch to get just right...  I finally got the new regulator installed and plumbed in...  I also got the oil fill welded in my 440Source driver's side valve cover...
that's really some nice work.
oh well, not being able to go the world street finals in orlando this weekend i worked on the demon. the headers are completed on the drivers side. the passenger side is almost done but i need help tightening the bolts on the that side. i wraped the #1 and #2 tube with heat wrap and install that damn diaper. jheeze what a hassle but it's in there. installed the egt's in #'s 1,2,7 and 8. #'s 3,5,4 and 6 need an adaptor made but they are in the header and though the firewall ready to go in the computer. the rpm pick-up is in and grounded also. i pulled the fuel pump off tosend it out to get rebuilt. well that's about it for today. oh ya, it ought to be done this week.
jacks62440
Sounds Good BoB . I am probably 3 years behind you  This weekend I finished the modifications to my K-member for oil pan clearance and put the engine/trans back in . 7/8" clearance now from nothing
Jack
