Topic: What is Everyone Working On? Volume 2 (Read 14942 times)
I wish I knew what happend with Mike.
Megajoltman
Well after being in the Hospital for 2 months and told I won't be allive in 6 months I 'm out feeling much better and put new rear lift leafs in my Ram to level it with the front.
building a 69 383 dart
Daily Driver 1998 Ram CTD 12V 4x4 Quad Cab Auto Shortbox, 3in Carli lift with custom rear lift springs (no factory blocks anymore) DSS Steering Stabilizer, 315 Toyo Open Country M/T tires
CudaDon65
This is some work I've done the last two weeks..
sycboi
 Did those vents fit right in there like that? I have an A-10 dash as well. I bought the Hot Rod Air brushed aluminum directional vain vents and there is no way in hell they will fit the dash holes. Maybe I could machine some of the outer perimeter off to make them go, but I would hate to have them fall apart on me if I took too much aluminum away. -Michael
Michael, PM me your # they fit just fine. I will tell you what you have to do.
Finally a day with some car work! I put her up on the lift and pulled the tranny, swapped the flexplate, put the tranny back in the car...Tomorrow I'll be installing the fuel system, pump, filter, lines etc. and hopefully get the radiator mounted...  Ryan
Bigcube
Well... good news and bad news. I warmed it up sat, ran the valves and pulled it out to wash it.  Well that's where the good news stops. I started it up to put back in the garage and it quit, no spark  So I tested the pickup, it seems to be working but the coil test's like it's shorted. I ordered a new one and it should be here tomorrow.  I still hope to beat the crap out of the car on fri for putting me though this
BrianT
It's 1978 all over again!!
Got a little progress done on my interior project today. My son and I installed the recovered back seat and started fitting the new carpet set!
 67 Dart 340 "Doing everything ass backwards"
DusterDave
Just finished painting my Duster black, so I'm doing the cut'n buff routine on it. Once that is complete, I can attack the short list. - Install polyurethane LCA bushings - DONE - Paint LCA's, steering box, an A-arms metallic silver - DONE - Replace front windshield - DONE - Buy & install new door weatherstripping - DONE - Install new oil pump - DONE - Replace burnt pushrod - DONE - Buy new starter - DONE - Install new set of valvesprings - Decided not to do - Install motor & trans -DONE -Install headers - DONE - Install K frame and front suspension - DONE - Clean up interior and trunk - Reconnect all wiring and hoses, etc - Fire up engine - Get front end alignment - Show off new paint job!  Click http://hemiduster.com/black_paint.htm for latest pics.
DustMan
Working on my first ground up build. Finished my chop a while back.  Yep, thats an 8 3/4 Rear. Now its about finishing up the Chassis...  And being able to use my Pineapple Grenade as a shifter  Here are my Grill choices. I'm thinking the black and silver 32 one, whatcha' think?  Been a few months of work, but this will be one nasty hot rod pick up. I think she will weigh in around 1800lbs
The enemy of performance is weight
A chop is pretty daunting........all flat glass I suppose in that hot rod, makes it a little easier. Looks good
DustMan
Thanks man, yeah the chop was a challenge, not because of the chop itself but because I raked the windshield back Bonneville style. A regular chop would have taken me a week, the raked windshield chop took 3 months. Its chopped 6.5", and yeah, the windshield will be 2 piece flat glass. The next one I do will be much faster. You learn so much building a vehicle from scratch.
FastmOp
This is a ford I been building for a wile, we blew it up once in the driveway but now it's running again. 357ci Cleveland with Boss 302 heads and a 6-71, herbert roller, 5500 stall bla bla Sorry for the ford post but I did drive it today for the 1st time ever. He hopes it outruns the Valaint.
Ed
working on a '71 454 4 speed vette, but only at night, don't tell anyone
formerly VIN_VL29U
CudaDon65
Working on the back seat...so far so good.
CudaDon65
I did some painting last weekend..first time I ever painted with a paint gun. The paint came out OK I think. Its eastwoods quarter mile candy red, single stage urethane enamel and epoxy primer. Here are some pics.
GTS Cowboy
Looks geat!!
 Life begins @ W.O.T.
DustMan
That does look great. Good job man!
satellite65
Hot color. What's that? candy tangerine?
CudaDon65
Thanks, it's a candy red but under all the lights and the flash of the camera it looks a little orange.
satellite65
Still smokin'. Can't wait to see it finished. (can't wait to see MINE finished either)
finally the light of day.
trial fit up on the trailer. me and abrasive modified the trailer so we wouldn't have to use boards on the ramps to load up. worked with plenty of clearance for the first time.
GTS Cowboy
Let's hear that bitch run!!...YEEEHAAAA!!!
FastmOp
Congrats Bob on getting it that far. I really hope someone gets vids, that thing is going to be bad ass.
smitty72
making some progress on the beast, the 6 point roll bar is done. got the bar painted today. I will be putting the headliner in when I get the time nad the weather permits. after that I will get the carpet in  . make the wifee happy I will clear up some of my storage space.
golferjohn
It may not look like it, but we're moved-in and cozy. Haven't moved for 13 years...what a pain!!
GTS Cowboy
Congrats...Nice looking place...do we get the tour?
