Topic: Moving rear axle back 2"... (Read 1007 times)
mopardad
Has anyone here ever considered moving the rear axle back 2" to eliminate rubbing larger tires on the front of the wheel opening? I was thinking about doing this when I move the springs in. Does it sound like a good idea? Mike
Im in the process of moving mine back an inch. With 2", make sure the shock isn't at too much oof an angle.
mopardad
Thanks...I didnt even think of the shock angle.Ill have to do something with that, too.
Moving it that far back may also hit the gas tank.
'67 Notchback- 12.85 @ 109mph
I moved the Demon's back approx 1 1/4" with no problems at all...Shock angle is fine...
Ryan
mopardad
It will have a trunk mounted fuel cell.
rank
How did you guys do this?  ?? Shim the front spring hanger?
mopardad
Thats pretty much how I was planning on doing it, adding about a 2" spacer in there or fabbing a new box for the front of the leaf spring.
A13Dart
Don't think you need two inches. What type of car and how tall are the tires?
mike.
How did you guys do this?  ?? Shim the front spring hanger? My leaf springs are relocated to the frame rails, so I just had to drill a new hole for the front mount... Ryan
mopardad
mike.
Its a 72 Valiant, and I will be using the 29x10.5 Hoosiers.
I'm not sure about it, but make sure the rear shackle doesn't hit the rear frame crossmember. You may have to use longer shackles. Just a thought.
Lars
You guys that have done this, did you change/mod the shackles in any way? I was thinking about doing this to my 73 when I put an 8 3/4 in it so I don't have to cut the driveshaft (plus it'll be getting some tall rubber in there later on).
caper
I moved my rearend back 1 1/2" , also put the springs inboard under the frame rails using te MP boxes. I also have mono leaf springs and Caltracs. The eye in the front of my spring is in the stock position , except that is moved in. The mono springs are a two peice spring , the center bolt attaches the two springs together , I had Calvert drill another hole 1 1/2 forward in the front half of the spring, this allowed me to extend the length of the front spring by 1 1/2" , therefore moving my rearend back by 1 1/2 ". Now when you drill a hole in your frame for your rear shackle you drill it 1 1/2 " back towards the rear bumper.This will keep the proper angle for your shackle. If you move back any further than 1 1/2 " I think you will be into the rear of the wheel well. I am running a 295 x 65 x 15 tire ( about 30" ) , it is very close to being centered in the wheel well.
Cudadust
The wheel bases on Plymouth A-bodies (Demon, Dodge Dart) are 108" and the Dodge ( Scamp) A-bodies 111", both models use the same springs. Wonder where Mother picked up three inches?
A13Dart
Its a 72 Valiant, and I will be using the 29x10.5 Hoosiers. 72 Valiant would have different shaped wheel openings than my 68 Dart. I made temporary spacers to move my rear axle back 5/8" to clear a Hoosier 9x30 radial slick, it measures 29-1/4" actual. Might be best to mock this up with the stock front spring hangers and some spacers before installing your inboard spring kit. mike.
68Valiant
mopardad,
I moved my springs rearward 1.75" at the same time I moved them inboard on my 1972 Plymouth Scamp. I had no adverse problems from this. I believe any more than that you will hit the rear cross frame rail at rear bumper with your shackel.
68Valiant
mopardad,
68Valiant
68Valiant: Did you drill your hole for the rear shackle any lower or is it at the stock height?? Also, did you use stock shackles?
68Valiant
mopowers,
I used stock height and shackels. I will look for pictures.
68Valiant
mrhotrod
I moved my rearend back 1 1/2" and am running a 28x10.5-15 slick on my 72 scamp. If you are planning on running slicks calculate enough clearance for tire growth. Before I moved mine back I cut a slick and they were 28" tall. and cleared but when running at the track they grew and rubbed. Just a thought for you.
1972 Big Block Scamp 9.80 @ 138mph 2006 Cummins Turbo Diesel Ram 4x4 Dually 1966 Plymouth Valiant Big Block Project Car
Blue
Just shifted mine back 3/4", redrilled the frame rail and moved the rear shackle back the same amount. Shocks used to clear fine but I had to mod the lower mount when the axle got a backbrace, now even those big 'ol rancho shocks clear.
I did that in my Satellite but I just drilled the hole in the shock plate and slid the rear back on the springs. Sounds a lot easier that the major mods you guys are discussing - would this work for you?
mopar stu
that changes the geometry of the rear, that may cause traction problems.not sure but i think axel/spring allignment is more important that spring/bodyweight allignment.
mopardad
It might, but since I have the rear down and Im relocating the springs I figure I may as well make the adjustments there and be done with it.
that changes the geometry of the rear, that may cause traction problems.not sure but i think axel/spring allignment is more important that spring/bodyweight allignment. Moving it back 2" isn't going to change any geometry. That part of the spring is pretty flat. What's important is that your pinion angle is correct, and that can be modified with shims. The slightly longer front spring section may try to wind up a bit, but if you've got decent springs and clamps that's not an issue. To each their own - just trying to help out.
smitty72
I had mine moved back just far enough to center the wheel in the opening. I dont tremeber how far it really was 1-2 inches, the springs are moved in to the frames rails the shop taht did the work had to adjust the shock plates a little to get the shock angle right but they didnt touch the top shock mounts
