December 04, 2008, 06:05:36 PM
| | |-+  Moving rear axle back 2"...
Author Topic: Moving rear axle back 2"...  (Read 1013 times)
mopardad
PERRY FAMILY RACING
« on: July 18, 2006, 09:02:09 PM »
Has anyone here ever considered moving the rear axle back 2" to eliminate rubbing larger tires on the front of the wheel opening? I was thinking about doing this when I move the springs in. Does it sound like a good idea?
Mike duster
Re: Moving rear axle back 2"...
« Reply #1 on: July 18, 2006, 10:15:41 PM »
Im in the process of moving mine back an inch.  With 2", make sure the shock isn't at too much oof an angle.
mopardad
PERRY FAMILY RACING
« Reply #2 on: July 18, 2006, 10:29:22 PM »
Thanks...I didnt even think of the shock angle.Ill have to do something with that, too. thank you
Saint Paul, MN
« Reply #3 on: July 18, 2006, 11:29:14 PM »
Moving it that far back may also hit the gas tank.
'67 Notchback- 12.85 @ 109mph
Merrimack NH
strange246 strange2462000
« Reply #4 on: July 18, 2006, 11:58:33 PM »
I moved the Demon's back approx 1 1/4" with no problems at all...Shock angle is fine...
Ryan
Dr. Hunter S. Thompson
mopardad
PERRY FAMILY RACING
« Reply #5 on: July 19, 2006, 06:43:54 AM »
It will have a trunk mounted fuel cell.
rank
« Reply #6 on: July 19, 2006, 07:56:18 AM »
How did you guys do this?Huh??
Shim the front spring hanger?
mopardad
PERRY FAMILY RACING
« Reply #7 on: July 19, 2006, 09:10:42 AM »
Thats pretty much how I was planning on doing it, adding about a 2" spacer in there or fabbing a new box for the front of the leaf spring.
A13Dart
Minnesota
« Reply #8 on: July 19, 2006, 10:32:54 AM »
Don't think you need two inches. What type of car and how tall are the tires?
mike.
Merrimack NH
« Reply #9 on: July 19, 2006, 11:03:28 AM »
My leaf springs are relocated to the frame rails, so I just had to drill a new hole for the front mount...
Ryan
mopardad
PERRY FAMILY RACING
« Reply #10 on: July 19, 2006, 12:35:04 PM »
mike.
Its a 72 Valiant, and I will be using the 29x10.5 Hoosiers.
« Reply #11 on: July 19, 2006, 03:23:34 PM »
I'm not sure about it, but make sure the rear shackle doesn't hit the rear frame crossmember.  You may have to use longer shackles.  Just a thought.
Lars
ATX
« Reply #12 on: July 19, 2006, 04:33:38 PM »
You guys that have done this, did you change/mod the shackles in any way? I was thinking about doing this to my 73 when I put an 8 3/4 in it so I don't have to cut the driveshaft (plus it'll be getting some tall rubber in there later on).
caper
Cape Breton , Nova Scotia
« Reply #13 on: July 19, 2006, 05:40:32 PM »
I moved my rearend back 1 1/2" , also put the springs inboard under the frame rails using te MP boxes. I also have mono leaf springs and Caltracs. The eye in the front of my spring is in the stock position , except that is moved in. The mono springs are a two peice spring , the center bolt attaches the two springs together , I had Calvert drill another hole 1 1/2 forward in the front half of the spring, this allowed me to extend the  length of the front spring by 1 1/2" , therefore moving my rearend back by 1 1/2 ". Now when you drill a hole in your frame for your rear shackle you drill it 1 1/2 " back towards the rear bumper.This will keep the proper angle for your shackle. If you move back any further than 1 1/2 " I think you will be into the rear of the wheel well. I am running a 295 x 65 x 15 tire ( about 30" ) , it is very close to being centered in the wheel well.
Cudadust
« Reply #14 on: July 19, 2006, 05:57:44 PM »
The wheel bases on Plymouth A-bodies (Demon, Dodge Dart) are 108" and the Dodge ( Scamp) A-bodies 111", both models use the same springs.  Wonder where Mother picked up three inches?
A13Dart
Minnesota
« Reply #15 on: July 19, 2006, 06:41:43 PM »
Quote
Quote
72 Valiant would have different shaped wheel openings than my 68 Dart. I made temporary spacers to move my rear axle back 5/8" to clear a Hoosier 9x30 radial slick, it measures 29-1/4" actual.
Might be best to mock this up with the stock front spring hangers and some spacers before installing your inboard spring kit.
mike.
68Valiant
Parkersburg, West Virginia, USA
« Reply #16 on: July 19, 2006, 07:48:51 PM »
mopardad,
I moved my springs rearward 1.75" at the same time I moved them inboard on my 1972 Plymouth Scamp. I had no adverse problems from this.
I believe any more than that you will hit the rear cross frame rail at rear bumper with your shackel.
68Valiant
« Reply #17 on: July 19, 2006, 08:24:42 PM »
mopardad,
68Valiant
68Valiant:  Did you drill your hole for the rear shackle any lower or is it at the stock height??  Also, did you use stock shackles?
Merrimack NH
« Reply #18 on: July 19, 2006, 08:29:44 PM »
I used sliders to avoid any shackle problems  Wink
Ryan
68Valiant
« Reply #19 on: July 19, 2006, 09:15:02 PM »
mopowers,
I used stock height and shackels. I will look for pictures.
68Valiant
mrhotrod
Chicago,IL
mrhotrod1964@hotmail.com mrhotrod1964
« Reply #20 on: July 19, 2006, 10:17:59 PM »
I moved my rearend back 1 1/2" and am running a 28x10.5-15 slick on my 72 scamp. If you are planning on running slicks calculate enough clearance for tire growth. Before I moved mine back I cut a slick and they were 28" tall. and cleared but when running at the track they grew and rubbed. Just a thought for you.
1972 Big Block Scamp 9.80 @ 138mph
2006 Cummins Turbo Diesel Ram 4x4 Dually
1966 Plymouth Valiant Big Block Project Car
Blue
« Reply #21 on: July 20, 2006, 12:42:17 PM »
Just shifted mine back 3/4", redrilled the frame rail and moved the rear shackle back the same amount. Shocks used to clear fine but I had to mod the lower mount when the axle got a backbrace, now even those big 'ol rancho shocks clear.
« Reply #22 on: July 20, 2006, 10:19:10 PM »
I did that in my Satellite but I just drilled the hole in the shock plate and slid the rear back on the springs.  Sounds a lot easier that the major mods you guys are discussing - would this work for you?
mopar stu
« Reply #23 on: July 20, 2006, 10:44:26 PM »
that changes the geometry of the rear, that may cause traction problems.not sure but i think axel/spring allignment is more important that spring/bodyweight allignment.
mopardad
PERRY FAMILY RACING
« Reply #24 on: July 21, 2006, 05:51:03 AM »
It might, but since I have the rear down and Im relocating the springs I figure I may as well make the adjustments there and be done with it.
« Reply #25 on: July 21, 2006, 08:03:36 PM »
Moving it back 2" isn't going to change any geometry.  That part of the spring is pretty flat.  What's important is that your pinion angle is correct, and that can be modified with shims.  The slightly longer front spring section may try to wind up a bit, but if you've got decent springs and clamps that's not an issue.
To each their own - just trying to help out.
smitty72
I'll finish it someday
« Reply #26 on: July 22, 2006, 07:19:16 PM »
I had mine moved back just far enough to center the wheel in the opening. I dont tremeber how far it really was 1-2 inches, the springs are moved in to the frames rails the shop taht did the work had to adjust the shock plates a little to get the shock angle right but they didnt touch the top shock mounts
