Topic: wiper arm removal? (Read 328 times)
GT451
I tried a search, no results, but what is the easiest way to remove wiper arms? I tried pushing and pulling on the little clip right under the pivot, but still no luck. I don't want to pry too har against the cowl. Any pointers? Thanks.
get a paint stick and a little prybar. set the stick on the paint and lift the wiper arm up as high as it will go. pry it up off the post.
GT451
I'll give it a shot, thank you.
DartKnight
If it doesn't give right away, don't get too nuts with it or you'll damage the seals in the cowl and develop leaks. It's a serious PITA to replace those things...
Jason
GON_RACIN
If it doesn't give right away, don't get too nuts with it or you'll damage the seals in the cowl and develop leaks. It's a serious PITA to replace those things...  i just did my wiper pivot/cowl seals about a week ago and it was MOST unpleasant. My neck still hurts
thebankerstoy
I bought a windshield wiper arm removal tool from Year One. It's part # T81 and runs about $17.00. It has two arms that fit between the cowl and the bottom side of the wiper arm. Once the tool is in place, all you do is squeese the handle and the two arms on the tool expand and push the wiper arm off of the stud. The arm on the tool that sits on top of the cowl, has a rubber coating, so it doesn't scratch the paint. It's a great little tool and well worth the money.  Richard
When I die, I'm taking my 66 Coronet 500 WITH me! God member on old forum with 1276 posts
wilddriver
Thanks for the info Richard
