December 01, 2008, 05:26:03 PM
| | |-+  subfame connectors
Author Topic: subfame connectors  (Read 780 times)
74DDS
Lakeville/Mankato, Mn
subfame connectors
« on: July 21, 2006, 04:56:01 AM »
Quick question, what is the better type of subfame connectors the bolt in type that you can pic up form mancini, jegs.... or the weld in type that you guys are making? I'm just curious because I'm getting anxious to do more things to my dart and I'd like to put a set in ( I do have axcess to a welder). Also whats the best choice for shocks for the strip with super stock springs? Thanks.
tubtar
Re: subfame connectors
« Reply #1 on: July 21, 2006, 09:31:24 AM »
I welded up connectors for my '65 .......there didn't seem to be a lot of store bought stuff available , and other than cutting up the floor it was easy.
As for the shocks.....http://www.bigblockdart.com/index.php/topic,7966.0.html   ......maybe we'll get an answer here.
I am in St. Paul , and nearly finished with the car.
I'd be happy to buzz down your way for a Thursday night cruise deal at that restraunt who's name escapes me at the moment and you can use my car as an example of what not to do to your ride.
        J.S.
It's a fine line between " how much ? " and " Why the hell not ? "
« Reply #2 on: July 21, 2006, 10:00:34 AM »
Bolt-in connectors are not going to be as stiff as welded. It is also considerably cheaper to make your own, and not that hard to do.
Birdius Rapidus
« Reply #3 on: July 21, 2006, 10:38:24 AM »
 agree agree What Jim said.
I have a larger pic in the gallery of a prepped frame connector. Cut a little, test fit then cut a little more. Same goes for the floor pan.
Non Mopar related, but my buddy put some bolt on connectors on his '65 Mustang small block with 360 hp at the wheels. The body has one inch long tears in the body on each side right behind the rear back seat roll up windows. Guess he should have welded some in.
Tom
DartKnight
« Reply #4 on: July 21, 2006, 11:08:27 PM »
On a Charger I once had, the previous owner had installed the bolt on connectors and then welded them to the frame. Seemed to work ok.
Jason
bentwheel43
« Reply #5 on: July 21, 2006, 11:59:58 PM »
  The bolt on one are to sell them,to make them work right weld it. It will help reaction &60ft. times at the  track.
xmattxxx
« Reply #6 on: July 25, 2006, 04:54:51 PM »
 I bought a set of mopar bolt in connectors and welded them in my duster,to be honest they suck.......i dont like the huge gap between them and the floor.Im thinking of filling this space in this winter,my advice is buy some that tuck up tight or build your own.
demon340v
« Reply #7 on: July 25, 2006, 06:40:15 PM »
if you were to  build your own is there a online guide somewhere just for MoPar's?
Swingin A 440
« Reply #8 on: July 26, 2006, 10:54:57 AM »
Good question. I've been wondering the same thing. I bought a set of MP bolt in connectors a year ago. I haven't installed them and have heard that weld in w/ torque boxes (like Auto Rust Technicians) is the better way to go.
Opinions?
I hate the thought of having to resell my parts, at a loss in order to get it right. However, I would rather have it right and spend a bit more to make it so. I hate that nagging feeling in the back of my brain saying, "you could have done it better."
-Jeffrey
3406pk
« Reply #9 on: July 26, 2006, 04:11:03 PM »
I did a set of subframe connectors on my 74 Duster made from 2x2x1/4 tubing.  We cut and fit them to fit tight against the rear floor pan without cutting into it.  Then we welded them to rear subframe and torsion bar crossmember.  They fit really nice and drop about a 1/2 in. below rear subframe.  We gusseted them to the rear subframe, but I don't think that you would need that.  I think that 3/16" wall tubing would work as well with less weight.
bentwheel43
« Reply #10 on: July 26, 2006, 04:37:55 PM »
What are you saying thay don't work or can't work because of the gap ? What is it a 9 second car?
Ryan (Strange246)
Merrimack NH
strange246 strange2462000
« Reply #11 on: July 27, 2006, 01:03:14 AM »
http://www.bigblockdart.com/techpages/connectors.shtml
Dr. Hunter S. Thompson
guzzimike
1968 Dart GT (383)
« Reply #12 on: July 27, 2006, 02:00:14 AM »
We built our own mostly per the instructions in the post above. We did have to cut 2ea.  3" X 10" rectangular holes in the rear floorpan as the connectors do come throught the floor a little bit. Total cost was under $40.00, if I recall correctly. Works great..
Cudadust
« Reply #13 on: July 30, 2006, 06:22:46 PM »
I use the ones from Mopar, I bolt them in then have the muffler shop weld them in place.  They appear to work correctly, when the car is jacked up at the front side the entire car lifts until the rear wheel sc clear of the ground.
