December 01, 2008, 11:08:22 AM
| | |-+  torsion bar removal
Author Topic: torsion bar removal  (Read 562 times)
Evan
Fayetteville, Arkansas
bigjohncat
torsion bar removal
« on: July 30, 2006, 03:26:34 PM »
once the car is on jack stands and the adjusters are backed all the way off, and the clips are out, how do i get the torsion bars to slide out? thanks,       -Evan
abodyjoe
South Jersey...
abodyjoe
Re: torsion bar removal
« Reply #1 on: July 30, 2006, 04:11:27 PM »
i usuallu have the lower control arm nut backed off and the strut rod nut backed off and bang the lower cantrol arm back and it will usually push the bar out the back...
fourspeed
Wisconsin
« Reply #2 on: July 30, 2006, 05:36:08 PM »
 agree
Pop the lower ball joint loose so the LCA can move easily. Loosening the LCA pivot nut is the way to go.
Cudadust
« Reply #3 on: July 30, 2006, 06:08:51 PM »
Did you remove the bump stops for the UCA, the front suspension should be at its lowest point for removal and installation of the torsion bar. Use the proper tool to remove the torsion bar, maybe your local parts store will loan you one, the local alignment shop, a shop class at the high school or college.  You can also purchase suspension tools for a reasonable price from Just Suspension 800-872-1548 and others, these tools are from American Muscle www.americanmuscle.biz which have a large list of vendors.
bentwheel43
« Reply #4 on: July 30, 2006, 06:38:49 PM »
  This is what I use, take the wire clip out and loseing the bar and hit the flat part of the clamp and drive it out the back.,this one was used over 10 times I know. Don't let it slide on the bar put it on good. This one is 1" cable clamp because my bar is .910 it cost less then $5
Evan
bigjohncat
« Reply #5 on: July 30, 2006, 08:17:22 PM »
i like that clamp idea. do i have to loosen the nut that holds the LCA to the K frame?
fourspeed
Wisconsin
« Reply #6 on: July 30, 2006, 08:31:52 PM »
No, but it makes it easier if you do.
abodyjoe
South Jersey...
abodyjoe
« Reply #7 on: July 30, 2006, 08:42:56 PM »
  if your gonna use the clam idea then no..  nbut if you are gonna bang the control arm back then yes loosen the nut for the control arm and also the strut rod nut.
Evan
bigjohncat
« Reply #8 on: July 30, 2006, 09:34:50 PM »
ok, thanks. if i cant get it one way, i'll try the other. thanks a bunch.          -Evan
rharley5652
« Reply #9 on: August 13, 2006, 04:03:56 PM »
CHECK THIS SITE OUT,..   http://www.4secondsflat.com/torsionbarremoval.html
   THEY TELL YA HOW TO MAKE A TOOL JUST FOR THIS PROBLEM  hammer
duster453
« Reply #10 on: August 14, 2006, 09:46:05 PM »
HEY EVAN,
I like your car and that is an AWSOME burnout COOL!!! 4 speed
p.s. the guys are right on with the t-bar removal agree
CFster
64 Polara 500
MAXCFster MAXCFster
« Reply #11 on: August 14, 2006, 11:13:08 PM »
Hee hee hee...
Evan
bigjohncat
« Reply #12 on: August 18, 2006, 12:21:45 AM »
Hee hee hee...
lol i took some out like that once too!!
