December 01, 2008, 10:53:16 AM
| | |-+  ignition trouble
Author Topic: ignition trouble  (Read 319 times)
slow_motion
Truckville, the capital NY
ignition trouble
« on: July 30, 2006, 08:34:30 PM »
Anyone got ideas why i went thru 2 ignition ecu's in 2 days? First one was a stock box, second one was the gold race box. All stock wiring ('85 ram), MSD blaster ss coil, probably stock resister too id imagine, distributor is stck style, and i reworked the curve in it. Im baffled.
--chad
Formerly: 400dart, 4523 posts on old board.
Recovering racing addict and turbo junkie
'85 D150 stepside, lowered, magnum 360
'96 Dakota,3.9, 2" drop, GenIII wheels
'95 Ram, her truck
'71 Duster, her car, 318/air, stock
'20 Model T pickup, stock
lake worth, florida
55robert@comcast.net
Re: ignition trouble
« Reply #1 on: July 30, 2006, 08:49:57 PM »
well for one the gold box takes a special coil and it's a race only deal. the stock one probably just got to it's end.
slow_motion
« Reply #2 on: July 30, 2006, 09:02:35 PM »
Bob, i was figuring i'd be flirting with disaster idleing it for so long with my setup---damn, those things arent cheap either----well at least i have no more race cars that i COULD have used it in. I guess i'll get another stock one and see what happens----just didnt know if i had a trend going here.
--chad
'95 Ram, her truck
Crazy68Dart
« Reply #3 on: July 30, 2006, 11:24:43 PM »
I am not up on the Mopar ignitions but are you certian they are getting the correct voltage?
Ed
Phoenix, Az
« Reply #4 on: July 31, 2006, 01:48:47 AM »
Make sure the box is grounded, no good ground, no go
formerly VIN_VL29U
DartKnight
« Reply #5 on: July 31, 2006, 04:56:27 AM »
I agree; those are not for street use. I like the orange box, myself; that's the most I need for right now. I have it grounded with one of those braided straps they have in the parts store Help section.
Jason
slow_motion
« Reply #6 on: July 31, 2006, 07:47:12 AM »
I cleaned up the grounds alredy. I was using the gold box as its all i had around at the time. The alternator is putting out a consistant 14-14.5 volts. This has a 2 prong ballast in it which makes me think that it has been swapped. I really want to say at one point, there was an orange box/mopar performanc dist setup in it, but im speculating. I have a much newer alternator as it was used on the magnum motor---could the older '85 voltage regulator be bad and causing this? Im going to get another stock box in a day or 2 and see what happens i guess. I unfortunatly have to buy another one to diagnose this thing.
--chad
'95 Ram, her truck
Ed
Phoenix, Az
« Reply #7 on: July 31, 2006, 10:47:24 PM »
Thinking out loud here, to kill 2 boxes,  you would think there's a wiring problem.  Now 14.5 volts isn't that bad, and it's really the coil that takes a beating with high voltage.  Unless it's the coil and ballast being to low a resistance and overheating the ECU.  All those parts have to be matched.  What's the voltage at the coil, both sides while it's running.  when you get it going again.
formerly VIN_VL29U
slow_motion
« Reply #8 on: August 01, 2006, 08:22:08 AM »
Huh, wonder if my coil is to much. Its a msd Blaster SS coil---like an e-core style.
--chad
'95 Ram, her truck
1DART440
« Reply #9 on: August 01, 2006, 09:51:08 AM »
That coil draws too much current. I remember that the old Accel Super coil had to have an extra resistor. Measure the resistance of the coil and compare it to a stock coil. There will be a difference.
slow_motion
« Reply #10 on: August 01, 2006, 06:45:29 PM »
hmmmmmm, thats not what i wanted to hear. I guess i needto step down on the coil. I had used the blaster ss before, but it was with a 7AL2 box. I ran a blaster 2 coil with the stock stuff before too. Hmmmmm, i guess it could be a case where more isnt better. Damn the hot rodder in me.
--chad
'95 Ram, her truck
