Topic: 3.5" or 4.5" 6-pak? (Read 941 times)
Crazy68Dart
I was looking at WS Racing's site and saw he offers two sizes for the 6-pak hood. Anyone have the 4.5" version on their car? If so, could you post a pic?
Thanks.
pandamarie
I will post a pic of my sons dart when I get back from Hot August Nights, 4.5 is stock 6 pac scoop height, I have it on my 69 charger too but its in the tranny shop.
Crazy68Dart
That would be great. How much actual room do you gain under it?
1969 360 DART
IM LOOK 4 A1OO SEAT BRACKETS THE PRO STOCK ONE 4 A A BODY DO U KNOW WHERE I CAN GET SOME
jamesdart
4.5" is stock size? i think my aar scoop is smaller than that. ill have to measure it. id like to have a little bigger scoop. with an m1 intake on a lowdeck, i just barely fit a 3" airfilter without a drop base.
jamesdart
just checked mine. its 3 1/4" from the hood to the top of the scoop across the front. id definitely go for the bigger scoop.
drjay0
263 Posts on old board. Member since March 2003. "Where the hell do i go to tell the world my dog died or my gf is in jail or my penguin ran away!" -njsuperbees
jamesdart
drjay0 you the new owner of that car?
drjay0
Crazy68Dart
James, how big is your air cleaner diameter? I am running the 400-2 MW Indy intake, and it is pretty tall.
Dr, How was the quality of the hood? Would it need much work to make it straight for paint?
Thanks.
Crazy68Dart
James, how big is your air cleaner diameter? I am running the 400-2 MW Indy intake, and it is pretty tall. Also, is yours an AAR or ??
Dr, How was the quality of the hood? Would it need much work to make it straight for paint? WS is about 1.5 hours from me, if that. I hear they do excellent work. Carter got his from them and really likes it.
I was going to ask if yours was a bolt on, but after reading the link, I guess not....
AdamR
That sucks Jason.
drjay0
Hood was super stiff for glass. It kind of bowed up in the middle making the fender seam hard to line up. Had to reach a happy middle and as usual only the owner (me) could tell. The USbody hood is on the way and that is a 3.5"inch sixpack. But the hood was real good quality. I have a 13inch pie plate with an 11 inch air element for an air cleaner. When you looked in the scoop to top plate lined up with the hood portion. It had a fists height between the top plate and the inside top of the scoop. The instake is a Weiand Xcellerator. Here is the engine compartment pic if that helps. I can send a larger image if needed. http://pg.photos.yahoo.com/ph/drjay0/detail?.dir=bfb4re2&.dnm=b103re2.jpg
jamesdart
i have the unscilenced factory type of air cleaner, i guess its 13 or 14" outside with a smaller element inside. the m1 is pretty tall, but probably not as tall as your indy intake.
