July 24, 2008, 01:00:20 AM
| | |-+  relocate springs?
Author Topic: relocate springs?  (Read 732 times)
Evan
Fayetteville, Arkansas
bigjohncat
relocate springs?
« on: January 12, 2006, 01:42:49 AM »
I'm not to this point on my dart yet, but I am just about ready. I've always planned on moving in my springs, but someone recently brought this to my attention: I'm building a car for handling - almost no strip use. Am I better off to leave the springs far apart? or will it make much difference? i need good traction, so I want the space for tires, but I care more about how it will handle. thanks         -Evan
70 Dustpan
Sacramento CA.
Re: relocate springs?
« Reply #1 on: January 12, 2006, 02:45:38 AM »
I'm a bit in the same boat as you are on this with my Valiant. With moving the springs in you do lose some stability, but this can be off-set by being able to use a wider tire in the back and using a good sway bar set-up. Also by repositioning your shocks to get them out as far as you can and reducing the amount of twist that your springs are allowed. I'm doing this with aluminum front bushings and slider rear shackles. I'm also only moving the springs in about 2 1/2" per side. If you do it the way the relocation kit says to you move them in around 4" per side, but I don't need that much to fit the size of tire I want to run.
Hey, I'm a God again!
Evan
bigjohncat
« Reply #2 on: January 12, 2006, 12:42:50 PM »
I always thought that there was no sway bar for relocated springs?
Dave_n_68_383S
« Reply #3 on: January 12, 2006, 02:43:53 PM »
the sway bar has no attachment to the springs, just to the axle and frame
Evan
bigjohncat
« Reply #4 on: January 12, 2006, 06:01:41 PM »
I see. So I guess I need opinions on whether I'm better off to go with factory spring location and a bar, or have the extra room w/ relocation and a bar.   what do you guys think?
jet-taz
« Reply #5 on: January 12, 2006, 06:43:18 PM »
you might try the off-set hangers from  mopar  if not  tub it. duster
Ft. Worth TX.
« Reply #6 on: January 12, 2006, 07:26:40 PM »
I have a 1in bar on my car with the springs relocated. When I get another camera. I will post more pics. Bill if you still have the one's I sent you post them please.
Cary Snyder
5.7L Hemi Cuda
