Topic: Pictures of pipe bender for Signet (Read 1239 times)
bentwheel43
This is some pictures of my $89.99 pipe bender for bending roll cage pipe it has 6 bending shoes, 1", 1 1/2", 1 3/4", 2", 2 1/4,and a 2 1/2". It will bend pipe with no problem it has a 12 ton rating. It takes some pipefitting skills to get it right.  I got it at a tent tool sale. In the pictures are the 1 3/4" and the 2 bigger shoes. [attachment deleted by admin]
allblknblue
Wow, that's sweet!
bentwheel43
Its made to weld to a work steel table and lay it down so that you can bend long pipe,see the 1" rould stock in the back of the second picture. But I bring it all over the place.
slow_motion
But pipe is not tubeing. Put in a piece of .130 wall roll cage tubing and see what it does. It crushes like a bad muffler shop exhaust system. But yes, things like gas pipeing and heavier stuff, it will bend reasonably well. I dont want gas piping protecting me in a crash---im sure it has a completly different tensile strength than mild steel tubing.
Formerly: 400dart, 4523 posts on old board. Recovering racing addict and turbo junkie
'85 D150 stepside, lowered, magnum 360 '96 Dakota,3.9, 2" drop, GenIII wheels '95 Ram, her truck '71 Duster, her car, 318/air, stock '20 Model T pickup, stock
wilddriver
how bout it bentwheel ever try to bend some thick wall stuff.
bentwheel43
Yes its 1 3/4" .134" wall mild steel. It dose a good job why you have one that won't ?
bentwheel43
thanks for the reply.
i know of this type of bender but i have never actually seen a bend made by one using tubing or pipe for that matter.
you're teasing me,ya got her loaded up and ready to go.
thanks again
slow_motion
Nope, it wont work on tubing, it will crush the tubing. I dont have alot into it so i dont mind, and i have used it for non auto stuff with no problems.
wilddriver
Nope don't have one at all,just trying to find a cheap one to start off with, and was intrested in what all you can do with the one you have.Thanks LARRY
bentwheel43
I bend roll bars I don't like to run the bars all the way back to the trunk, so I bend them and weld them to a 6"x6" .125"plate right over the back tires, and instead of cutting and making a swing out bar I put a bend in the sidebar,I use a Competition Engineering kit and use the bender on installation,we bend 30* and 45* when we need to . I did about 6 cars with it. I didn't try a 90* because I never had too. I guess I just got lucky. BENT43
wilddriver
Thanks you say you paid roughly 90 fo it,know where i can pick one up
bentwheel43
I bought it at a tent tool sale its almost 9 or 10 years but there arould,my bother bent a 30* on heavy 280 wall 2" with it I was rise'n hell when I come arould the corner of the shop.  for a truck bumper.
harbour frieght
68Valiant
wilddriver,
There is a harbour frieght store here in Parkersburg now. Let me know if I can help.
68Valiant
wilddriver
might have to stop by 68Valiant
I have that same bender and slow motion is right, bentwheel, got any pics of the bends? I used it for my cage too but more than a slight bend and it will crush the pipe...Welding a cap on one end, filling the pipe with sand and capping the other end will help with the crushing but it's heavy, dirty and a pain in the a$$ to do that.....But it's how I did my door bars... Ryan
bentwheel43
10-4 on the pain in the ass,this is a 24"piece I did . Its harder on a short pipe I started the bend at 12" on this piece, most A- body door bars are 48" to the break in the floor  but this is what mine looks like it didn't mark the pipe and would have bent it better if it was even 30" long. With no heat. [attachment deleted by admin]
Michael Deakin
I have got a friend's pipe bender that looks just like that and i would also agree with Slow motion about the pipe being crushed. I even tried filling them with sand and capping vthe ends and it still flattened the tubing but not as bad. I have got a hilmor bender that's very good for roll bar tubing. I used to have a tube bender looked just like the one you've got but a different make and that was also very good Mike
DA72RT
BigBlockDart.Com Clintonville WI.
pipe and tubing are measured different.One is measure by I.D The other is measured by O.D.If you can get the correct size mandrel for the tubing you wont have as many problems with the tubing collapsing.I saw a website for a tubing bender that the guy gives a list of materials and a company that sells the mandrels.I will check and see if I have it bookmarked.
FastmOp
I built my car with the same bender, only issue it gave me was the dimples from the rollers on both sides of the bend. but thats a non issue.
bentwheel43
![\/][](http://www.bigblockdart.com/Smileys/classic/finger020.gif) You got it, if you bending this stuff you can't just bend it, I been working with steel over  30 0 years,and I know that fastmOp has some years in too, I never use one break to bend a pipe,its almost just like the way DA72RT said it is, very close thats why a 24" piece is harder . I can bend them sexy too,its only rock'n roll. In this picture I ran it in the bender 4 times .500 a break. [attachment deleted by admin]
rebel
i built the cage in my car with one of those benders & everything worked out fine, to prevent dimples use the next size former up & all will look like a professional did it
bentwheel43
 If I had alot of cars to do I would want that $3100 bender, man that thing is fine.  They have alot of nice tool!!
BARRACUDABILLY
Here is the bender my buddy bought and we bent my bars with the web site is www.irvansmith.comSome of your NASCAR guys may remember Ernie Irvan? This is his shop near Charlotte NC, This bender is $1295 and works great. I hope the pic posted if not the model number is IS2-01-TB [attachment deleted by admin]
Rocky Ak
there is a JD2 Model 3 Tubing Bender on Ebay right now with a buy it now price of $295.00.
Rocky Ak
that price is just for the gizmo,no dies no stand no nothing,well you get the degree wheel now for free.
if i get one that will be it.
a local company has one on the floor for demos, it is a nice piece when you see it up close.
900 bucks Canadian with one set of dies for 1-5/8 6.5" radius no handle no stand.
