October 15, 2008, 08:03:57 PM
| | |-+  71 Demon alignment specs
Author Topic: 71 Demon alignment specs  (Read 529 times)
demon340v
« on: January 12, 2006, 04:42:18 PM »
hey guys i'm looking for all the measurements and points that everything should be at. i'm going to get my  entire frame aligned up on a jig so i was wondering if you guys had the specs for it?
Re: 71 Demon alignment specs
« Reply #1 on: January 13, 2006, 01:11:20 PM »
The original specs are sometimes dated. Best results will be with the maximum positive caster with a slight (very slight) negative camber (1/8 degree or so) and about 1/16" toe-in. Play with the caster to compensate for road crowns (a little more on the right)
demon340v
« Reply #2 on: January 13, 2006, 03:41:27 PM »
you don't happen to have like the 1 where it shows the bottom of teh car and gives the tolerences everything should be in?
that's what i'm basically looking for
« Reply #3 on: January 13, 2006, 07:17:50 PM »
I have shop manuals with factory specs. I don't like the way the factory measure ride height (too hard to check). I measure the distance from the LCA to the frame and like to have about 1" between the LCA bumper and the frame. I can post the factory numbers later.
demon340v
« Reply #4 on: January 18, 2006, 02:29:15 PM »
i went ahead and was able to track down a frame chart should be here umm tomorrow maybe it's coming from Texas.
dustertogo
« Reply #5 on: February 06, 2006, 11:02:24 PM »
 I have a 70 Duster and have been looking for frame specs for it for a while with no luck. It use to be a race car and is more that likely twisted some. I would love if you could post your Demon specs or please
e-mail them to me. Thanks very much.
Josh
« Reply #6 on: February 07, 2006, 08:43:20 AM »
I dunno about frame specs and such. But the factory alignment settings blow with radial tires.if it is a street car Jim hit the nail on the head with his suggestion.
