Topic: 71 Demon alignment specs (Read 540 times)
demon340v
hey guys i'm looking for all the measurements and points that everything should be at. i'm going to get my entire frame aligned up on a jig so i was wondering if you guys had the specs for it?
The original specs are sometimes dated. Best results will be with the maximum positive caster with a slight (very slight) negative camber (1/8 degree or so) and about 1/16" toe-in. Play with the caster to compensate for road crowns (a little more on the right)
demon340v
you don't happen to have like the 1 where it shows the bottom of teh car and gives the tolerences everything should be in?
that's what i'm basically looking for
I have shop manuals with factory specs. I don't like the way the factory measure ride height (too hard to check). I measure the distance from the LCA to the frame and like to have about 1" between the LCA bumper and the frame. I can post the factory numbers later.
demon340v
i went ahead and was able to track down a frame chart should be here umm tomorrow maybe it's coming from Texas.
dustertogo
I have a 70 Duster and have been looking for frame specs for it for a while with no luck. It use to be a race car and is more that likely twisted some. I would love if you could post your Demon specs or please e-mail them to me. Thanks very much.
Josh
I dunno about frame specs and such. But the factory alignment settings blow with radial tires.if it is a street car Jim hit the nail on the head with his suggestion.
