December 05, 2008, 02:02:25 AM
| | |-+  brake pedal return spring ?
Author Topic: brake pedal return spring ?  (Read 195 times)
tubtar
« on: August 16, 2006, 01:30:16 PM »
Is there such a thing ?  I have a '65 dart ....it had the single master cylinder when I got it...and it was shot.
The previous owner had a throttle return spring to keep the pedal up.
I now have a dual m.c. and the usual changes that go with it....front disc , proportioning valve etc.
When bleeding the brakes , I found that the pedal doesn't want to return to what seems like the right height.
Should there be a spring in there to pull the pedal back ?
Am I missing something else here ?
                                   Thanks again for your help,
                                                  John
69 GTS Clonvertible
GEAR+SLAMMER
Re: brake pedal return spring ?
« Reply #1 on: August 16, 2006, 02:57:19 PM »
From what I know there is not supposed to be a return spring. That would give a false since of having a good set of brake pads or a filled master cylinder, which in any case may get you into trouble down the road, if you add that throttle return spring back in under the dash.
Lars
ATX
« Reply #2 on: August 16, 2006, 06:04:01 PM »
None of my Mopars have one.
tubtar
« Reply #3 on: August 16, 2006, 10:20:18 PM »
Thanks gents.   I am using an adjustable push rod and a relocated master cylinder , so I figure to do some more adjusting and see where this leaves me......but I won't be worrying about a spring.
And one less question leaves me a little better off than I was yesterday.
                                        Ya'll rock !
                                             J.S.
