December 05, 2008, 02:07:23 AM
| | |-+  RMS front end is in...
Author Topic: RMS front end is in...  (Read 620 times)
540dust
« on: August 17, 2006, 12:25:21 AM »
Im about ready finally, new RMS front end, and a four link.  I lowered the stance a little.   I like it but am a little concerned with the oil pan being kinda low.  Its a little less than 3.5 inches off the ground but only in the very back, it angles up to almost 5 before it gets to the rack.   Hows the stance ?
440Demon
Streetsboro Ohio
Re: RMS front end is in...
« Reply #1 on: August 17, 2006, 12:42:50 AM »
That is one Bad Azz looking car.
« Reply #2 on: August 17, 2006, 01:10:19 AM »
Looks good. Maybe a little high in the front, but it also looks like you may have resized the picture and lost the aspect ratio as the car also looks short in the pic (or just a wierd angle - anybody else see it?).
dartracer
Strasburg CO.
« Reply #3 on: August 17, 2006, 09:12:48 AM »
Does look a little short. I like a more stock look, so maybe a little down in the front or up in the back.  Dave
Tubbed440
Suspension NinJa
« Reply #4 on: August 17, 2006, 09:17:08 AM »
I assume you made a "custom" rear mount crossmember for the trans?  Sounds like the trans tailshaft might be a little low in the car...or you may have the rear end too low for the ride height of the front end.  It's kinda hard to tell from the pics.
'74 Challenger, Full cage, 500 inch Wedge, 4L80E, ladder bars,
Coil-overs - 325/50/15 MT drag radials - Street Car!
BARRACUDABILLY
« Reply #5 on: August 17, 2006, 09:37:20 AM »
540
I like, I like very much, I am building the same set up with my 68 cuda.
What kind of front wheel is that? and where do I get a set?
Thanks for any help
B.B.
540dust
« Reply #6 on: August 17, 2006, 11:57:17 PM »
The difference in the pan clearance from back to front is a lot the pan design, although Im using a stock crossmember it had been modified for a powerglide and Ive been running it for about four years, it may be a little low but not more than a half an inch.  The pan is a modified Charlies dragster pan that Mancini sells with the two inch kick out.
The wheels are Weld billet alumnastars with the 2.25" bs.  I really like them a lot better than the 1.75" bs. They are readily available at Jegs or Summit but be prepared to heavily lighten your wallet.
Heres another angle.
These pics were before scaling and it sets a little different now, before there was a little difference between RR and LR in ride hieght now both are closer to equal (RR about 3/8" higher), before (in these pics) there was more of a difference.  Had to move a lot of stuff around to get it to scale properly.
540dust
« Reply #7 on: August 18, 2006, 12:01:50 AM »
Heres one more angle.
« Reply #8 on: August 18, 2006, 12:40:24 AM »
it looks good now.
the picture in your signature, are you running leafs and t-bars?
540dust
« Reply #9 on: August 18, 2006, 12:50:42 AM »
Leafs with an upper link bar.  Not a leaf link, the springs were still on the stock spring perches.
Administrator
White Haven, PA
« Reply #10 on: August 18, 2006, 06:43:56 AM »
How do you like the track width?
« Reply #11 on: August 18, 2006, 10:53:55 AM »
Those later pics look better.  thank you
540dust
« Reply #12 on: August 19, 2006, 02:49:35 AM »
Track width is at least 3/8" narrower than before, I really like it.  The Wilwood hubs put the tire 1/8" in the rest was your shorter a arms and the 2.25" bs wheels.  I think it worked out really well.  I havent made it down the track yet but so far I couldnt be happier with everything.
