July 09, 2008, 09:49:21 AM
| | |-+  '65 B body brake question
Author Topic: '65 B body brake question  (Read 605 times)
Blue
« on: August 19, 2006, 02:42:44 PM »
Guys, am I right in assuming that '73 Dart disc brake spindles will bolt straight in to a '65 Belvedere that currently has drums? Will I need to change the lower ball joint as well or not?
Blue
Re: '65 B body brake question
« Reply #1 on: August 20, 2006, 01:25:01 PM »
Anyone?
Mark Nixon
Nixon340 Nixon340
« Reply #2 on: August 20, 2006, 04:10:39 PM »
The B body lower balljoints will fit them, in fact, the uppers will too.
If you still have the single reservoir master cylinder, it will work with the disc brake conversion, though I suggest swapping in the dual reservoir stuff, just for the added safety of it.
I would also suggest using the 11-3/4" caliper mounts, calipers, rotors and pads, from a '76-'81 R or B body, on the '73-up A body spindles. This will require using 15" wheels, though.
Mark.
Transporting cars and parts, long or short haul.
I can deliver what I am selling.
Contact me by phone at (402)-780-5127 or by
e-mail at Nixon340@yahoo.com!!!
65rbdodge
jeff44044mag
« Reply #3 on: August 22, 2006, 04:20:51 AM »
it will fit. my disc set-up came from a 73 a-body and bolted right on to my 65 coronet.
65 coronet 440/4 speed/9.75
71 dart custom 4 door 400/727/8.75
03 dakota 239/5 speed/8.25
Blue
« Reply #4 on: August 22, 2006, 03:06:51 PM »
Excellent! I'll be fitting the booster and master cylinder as well then...
