December 05, 2008, 01:41:20 AM
| |-+  Early A-bodies
| | |-+  clutch and brake pedals
Author Topic: clutch and brake pedals  (Read 1073 times)
340fyd
« on: August 22, 2006, 12:48:32 PM »
Can somebody also give me a picture of their brake pedal on a standard car? I'm needing to know how much farther down they are compared to the clutch pedal. Thanks agian for your time.
Lee
Lee
sweatybetty
Re: clutch and brake pedals
« Reply #1 on: August 23, 2006, 12:04:54 AM »
if this doesnt help let me know and ill get a better pic
340fyd
« Reply #2 on: August 23, 2006, 07:40:27 AM »
I thought that the factory way was that the brake pedal sits a little lower down than the clutch.  Is this not correct?  I do appreciate the pitcure.
Lee
Lee
sweatybetty
« Reply #3 on: August 25, 2006, 10:12:42 PM »
across the tops (horizontally) they are even. if one sits higher up off the floor, not sure
lilcuda
« Reply #4 on: August 28, 2006, 11:01:32 AM »
Lee
On my 66, the clutch & brake pedal have always been the same height off the floor. The brake pedal is way too high for spirited driving, if you ask me. There's no way to heel & toe with the pedals at the stock height. I can't take a photo right now since the m/c & clutch pushrod are out of the car at the moment.
Lee (the other one)
1966 Barracuda, 340, 4 speed
jicaino
« Reply #5 on: October 31, 2006, 11:58:44 PM »
the clutch pedal has a rubber stop that goes under the lip of the brake/clutch assy. sometimes it gets lost and the mechanic just leaves you with your clutch almost 2" higer than brake pedal. I hate that !  explode
340fyd
« Reply #6 on: November 06, 2006, 09:07:27 AM »
Thanks, guys.
Lee
Lee
