July 05, 2008, 09:27:30 AM
| | |-+  Prop./ Brake valve
Author Topic: Prop./ Brake valve  (Read 14122 times)
496dart
Prop./ Brake valve
« on: August 23, 2006, 05:24:15 PM »
Ok guys, i need to know what you did as far as your proportional valve after the disc conversion.  My car is a 70 dart and i put 73' discs up front.
I have what is believed to be a 73-76 A body prop valve.  when i place it up on the frame,  none of the lines match up , as far as size and  rear/ front ports .   It really looks like i have to make all new brake lines  .  \/][
Is this what you guys had to do---or   how did you route everything  ?
Re: Prop./ Brake valve
« Reply #1 on: August 23, 2006, 06:12:03 PM »
I've always used the 73-76 a-body piece. You may have an F-body prop valve. Can you post a pic?
496dart
« Reply #2 on: August 23, 2006, 07:29:29 PM »
here it is:
« Reply #3 on: August 23, 2006, 10:31:34 PM »
Definitely NOT an a-body piece.
496dart
« Reply #4 on: August 23, 2006, 10:40:29 PM »
figures--i was told it was and bought it online .
anyone have one on here ?
« Reply #5 on: August 23, 2006, 10:47:41 PM »
I don't have a spare one, but might be able to get a pic of one so you know what you're looking for.
« Reply #6 on: August 23, 2006, 11:18:06 PM »
Here's one.
496dart
« Reply #7 on: August 23, 2006, 11:25:33 PM »
thanks - can u list what each letter corresponds to ?
« Reply #8 on: August 23, 2006, 11:55:08 PM »
Sorry,
A= master cylinder marked F for front, be careful it's actually the rear reservoir.
B= right front brake
C= left front brake
D= rear brakes.  They'll split downstream
E= Master cylinder marked R, again be careful this is the front or usually smaller reservoir.
B & C probably can be either way but A & E have to be correct.  You want the larger reservoir to apply the front brakes.
Thanks to Ryan from N.H. for applying the letters to the picture.
496dart
« Reply #9 on: August 24, 2006, 12:25:18 AM »
thanks !
larry408
« Reply #10 on: August 24, 2006, 08:15:08 AM »
I have a extra a-body proportional valve but it is packed for the move that we are making this weekend. If you do not find one and are interested in the one that I have just let me know and I will look for it next week.
Larry Gathright
1973 Dart Sport
USAF 68-72
NRA Life
440WIP
« Reply #11 on: August 24, 2006, 04:21:26 PM »
This is handy information.
Is it possible to put this thread (of the picture and the description) up into the tech pages?
Sixpak
« Reply #12 on: August 28, 2006, 05:36:15 PM »
I took this one out of a 75 Dart with factory discs....
496dart
« Reply #13 on: August 28, 2006, 10:08:30 PM »
hmmmm......that one looks just like the one i already have.  Huh
« Reply #14 on: August 28, 2006, 10:52:20 PM »
The one I posted came out of a 73 Valiant with factory disc brakes.
... it was the newer single piston type not the earlier K/H.
DartKnight
« Reply #15 on: August 29, 2006, 12:23:23 AM »
Weird...the bottom one looks like a B or E-body valve; The one I pulled for my brake swap came from a 74 Swinger with single-piston calipers and looks like the one ski posted. The other ones look like the valve I pulled out of my 74 Charger...I'm a little confused, also.  Huh If it is a dual-piston/single-piston difference, would either one work?
Jason
496dart
« Reply #16 on: August 29, 2006, 12:53:17 AM »
confused here too !
my car has 73' single pistons
Ed
Phoenix, Az
« Reply #17 on: August 29, 2006, 01:46:43 AM »
All my pre-73 cars have the brass square prop valve.  Ma mopar switched over to the cast iron valves sometime in the early 1970's except in trucks.
formerly VIN_VL29U
« Reply #18 on: August 29, 2006, 02:15:50 AM »
I'll see if I can dig out a 72 and earlier that went with the 4 piston K/H type.  If I remember right they look similar to the one I posted but not exactly.  It may take me a couple days to locate one.  Hey 496dart I would just get a 35 dollar adjustable one and plumb it into your rear brakes.
496dart
« Reply #19 on: August 29, 2006, 04:00:32 AM »
i  might do that--who has them for $35?
i got another one on the way  to try first
Lars
ATX
« Reply #20 on: August 29, 2006, 04:10:00 AM »
Summit Racing has them. Use the old drum valve and plumb the adjustable one into the line that feeds the rear brakes.
« Reply #21 on: August 29, 2006, 10:57:41 AM »
Take a look at the last one labeled 65-72 MOPAR.  Kind of looks like the one you have.
http://www.piratejack.net/proportioning_valves.html
Sixpak
« Reply #22 on: August 29, 2006, 11:38:03 AM »
I believe the factory started doing a slow transition from brass prop valves to the cast iron ones around the early 70's. Earliest example I can recall of seeing a cast iron valve is in a 71-72 C b body, then I think the E bodies got them in 72 or 73, probably the B bodies around then. I've seen brass valves in A bodies through 74 but after that in 75 most if not all had the cast iron valves. It's just a matter of the factory using up whatever they had in stock and then switching over to something else.
496dart
« Reply #23 on: August 29, 2006, 01:27:15 PM »
Thats gotta be the one i already have Ski
« Reply #24 on: August 29, 2006, 04:49:58 PM »
it shows in my 75 chrysler chassis manual that every line had a cast one
« Reply #25 on: August 29, 2006, 06:42:13 PM »
I just pulled two of the brass ones out of a yard today, along with the spindles. I didn't check the year of the cars, though.
wedgie
« Reply #26 on: August 30, 2006, 06:34:00 AM »
I know that the combination valve proportions front to rear, and turns on the brake malfunction light, but does it also contain the residual valve?
67 dartgts
Go fast or go Home
« Reply #27 on: September 02, 2006, 10:47:11 PM »
  Let me see if I understand and can confuse everything even more  The photo that Ski posted iss of the Safety Switch its function is to split the front wheel lines and warn of a system failure frot or rear.  The faiilure would be a break in the system that allows the fluid to drain to the point where the spring pressure inside the switch makes contact turning on the light .  To tell you you have lost fluid..the other system will of course work because it is complety seperate from the other.  If you took the safety switch out of the system.  The rear section of the Master plumbs direct and splits at the rear end.  The front section you can split with a tee to do the right and left.  There is no connection to the front and rear inside the switch.  The proporating valve merly allows you to adjust pressyure to the rear so all wheels brake equally..that is in a panic stop you lock front and rear wheels equally.
  Maynard
1967 Dart GTS(orginial owner) / 1967 Dart 2 door post 440  / 2001 PTCruiser / 2004 Dodge Ram Quad Laramie Hemi (small grage)
Cudadust
« Reply #28 on: September 03, 2006, 10:23:39 PM »
This is getting a little confusing, those early renditions were distribution valves with a position forow fluid pressure.  The later model combination valves provided some proportioning but this was negated with different tire\wheel combinations. The stand alone proportioning valve is installed in the rear brake circuit and adjusts the amount pressuse to the rears as a safety feature to prevent the rears from locking up first and causing the rear end to come around. www.moparaction.com is the definitive source for brake conversions on Mopar iron and should be consulted for more information.
« Reply #29 on: September 03, 2006, 10:39:29 PM »
