December 05, 2008, 02:22:58 AM
| | |-+  69 Dart drum to disc
Author Topic: 69 Dart drum to disc  (Read 335 times)
DART VADER
« on: August 25, 2006, 11:02:24 AM »
I'm getting ready to do the swap with the disc setup I bought from Jim Lusk (thanks Jim). Where can I find a proportioning valve? Are they still available at parts stores? Also are the wheel bearings the same for disc and drum? It's a small bolt pattern set up. Upper and lower ball joints the same?
These are things I just want to be aware of for future reference. After I pull everything apart I am going to get the rest of the parts I need.
bbd sign tried and true
Re: 69 Dart drum to disc
« Reply #1 on: August 25, 2006, 04:28:48 PM »
10 inch drums and both big and small bolt discs use the same bearings/seals. I just checked several sources and could not find a prop valve. I'll be out wrecking yard shopping tomorrow and I'll keep my eyes open.
jet-taz
« Reply #2 on: August 25, 2006, 06:00:25 PM »
mopar performance p5249088
DART VADER
« Reply #3 on: August 25, 2006, 08:22:50 PM »
Thanks for the info Jim.
Taz, what part is that number for?
jet-taz
« Reply #4 on: August 25, 2006, 08:51:18 PM »
adjustable brake proportioning valve
DartKnight
« Reply #5 on: August 25, 2006, 11:46:31 PM »
The Wilwood unit is pn# 260-8419; that's the one I have. I believe the MP valve is made by Wilwood also (at least they used to be).
Jason
DART VADER
« Reply #6 on: August 26, 2006, 12:30:00 AM »
Thanks guys. Looks like I will be gathering more parts next week.
HemiDoug
« Reply #7 on: August 26, 2006, 10:51:22 PM »
Fine Lines has a new brass combination valve that I plan to use for my disc brake conversion. It uses all the same tubing and fittins as the stock part. They were selling them for $70 at the Nats.
