Pages: [1] 2 3 ... 7
Topic: BigBlockDart - Fastest car list!! Post you 1/4 mile times.... (Read 28368 times)
12.81 on crappy street tires. had to baby it off the line..? one day we will get good tires on it and see what it can actually do...   71 dart 360 mp short blk. eddy heads performer rpm 780 holley 904 3:91 gear
72swinger
60 ft 1.50 10.94 121 mph street trim
10.94 at 121 mph street tires and mufflers , hoping for a little more
BLOWNZOOM440
it's in the sig and i am happy with it.
"69" SportSatellite,440,8-71/8lbs of boost,10.46/129
DA72RT
BigBlockDart.Com Clintonville WI.
10.5 in about 2 years.
Jack
Best of 11.97@114 with 440 Bulldog heads, 4.56 gears. Traction is not right yet. Unknown 4000 converter. Started to tweak the car, so I had a bar put in, and have not run it since.
71 Swinger- 440+.060, solid cam, Trackdog heads, 4:56, 8 pt roll bar, best 11.97 @ 114, pump gas, mufflers, street tires. "street car"
70-440
Hendersonville, TN
What about 1/8 mile times? Sure would like to see some of those! I've only got 1/8 mile tracks near me.
1.68 60 ft 7.50 @ 92 MPH
PinkE
A New Journey Begins.....
Numbers, Numbers Numbers...It's all about numbers with you guys....  ...Well my little 340 only gives me a 14.06...  ....but it's the thrill of doing it......That's the Thrill of Drag Racing...Don't matter what the numbers are....If you feel the adrenalin rush, then it's there, the time slips just a friekin piece of paper....It's a Thrill...a Rush, it's the feeling of SPEED that keeps this girls blood flowing through her veins.? Nothing else, not sex, not a present, not anything compares.....  Sorry, I removed my rediculous answer, must have been the beverages at Brunch this morning....
Swede
ok,don?t laugh,but the only mopar I?ve timed was my ?67 300,it had an untouched 350hp 440, 215x75x14" tires and an open diff,it was not on a real track,just measured somewhat like 1/8 mile,and my buddy clocked me:11secs flat,when I hit the throttle,the car didn?t move at all first,the right rear just went up in smoke,and didn?t stop spinning until like halfway.
Ed
I'm happy the /6 chirp the tires going in second the other day  Swede, that you from the old board? Long time no see if it's you
formerly VIN_VL29U
scaldeddog
The Dart is still under construction but the Dakota has gone 13.75 @ 99mph. When I started she was good for a 15.40.
Smokem' if ya gottem' 822 post on the old board
Brad4406
No 1/4 around here, but I do have a three 1/8 mile tracks nearby. The best the Duster has done with the 4-speed was 7.943. I blame part of that on the nut at the end of the shifter.  That is the fastest I've ever been, it's going to be a drastic change if my 500ci 4-speed '65 Barracuda that I'm building goes as fast as I expect it to. Brad
Dartman928
I've gone 9.81@147mph 1.5ish 60 ft. with my 500" street car
cudadon
69 Barracuda 451 9.56 ET @ 140 MPH Not bad for an 11.4:1 .600 lift flat tappet engine!
mrhotrod
10.44 @ 125mph 1.44 60foot so far still looking for traction
440c.i.
3320lbs with driver
1972 Big Block Scamp 9.80 @ 138mph 2006 Cummins Turbo Diesel Ram 4x4 Dually 1966 Plymouth Valiant Big Block Project Car
MegaDuster
My Duster has gone 8.75 @ 155 (I will in 2 months), I have gone 11.01 @ 122.38.
Formerly known as 493Charger
6469mopar
my 440 ran 9:86 ( 1/4 ) in a 2500 lbs car with a 727 now its in my dart with a 4 speed, didn't run it yet still working out bugs, my valiant ran 13:00 ( 1/4 ) spinning tires it has 340 727
68dartgts
12.40 about 10 years ago
AA-slingshot
mine is a 6.34 at 220 mph.....maybe someday i'll be rich again and go alittle faster.
PinkE
mine is a 6.34 at 220 mph.....maybe someday i'll be rich again and go alittle faster.  Maybe someday you'll smarten up and drive a Mopar....
Dartsport
mine is a 6.34 at 220 mph.....maybe someday i'll be rich again and go alittle faster.  What kind of car or Dragster was it  ? What motor? Thanks for info!!
383man
My 63 should be done by May this year. This is my sons 400 Dart street car. Best et so far 11.55 @ 116. Ron
Halfaed
I bet I have the fastest car with the smallest valves  Actually I don't even know about that, but I ran 14.21 @ 99.19 with a 1.88 valve headed 340, 4-speed and 3.23 suregrip.
AA-slingshot
mine is a 6.34 at 220 mph.....maybe someday i'll be rich again and go alittle faster.  What kind of car or Dragster was it  ? What motor? Thanks for info!! it's a blown alky funnycar.....kb engine with big chief heads.
BBLM23
11.64@115 Dot tires, mufflers, Mobil Super Unleaded
BOTTLE-FED_CUDA
I'll be the slow guy with a small block 11.89 @ 116.9 mph
street tires, full interior
-Ritchie
