Topic: ROCKY MOUNTAIN DASHES??? (Read 3999 times)
demon340v
I'm just saving now! i really can't wait to get my cluster replacement from you guys, going to slap in Auotmeter guages on mine
MikeR
Cool just let us know when you're ready (we have one in stock now for the 70+ A-bodys)
demon340v
Cool just let us know when you're ready (we have one in stock now for the 70+ A-bodys)  IN due time, gunning for November for it. it's 1 of those money maker months payday falls 3 times that month!
Sparkles459
That one is the A-10
Is the A-10 the only one with the AC vent bezels?
MikeR
Is the A-10 the only one with the AC vent bezels? At this point it is, we may introduce a new one if the folks at Ray Barton don't mind us using their layout...but that's a ways off.
jicaino
Loved those dashes. Contacted you guys (mike) and your customer service is excelent. Too bad We couldn't arrange for the "big" holes (speedo and tach) to be 4"...  I'd have loved to have one RMD on my dodge. keep up the good work.
Rate
Wow, I figured that custom dashes would be much more expensive then that >_>
*adds another item to his "want-to-buy" list*
65prostreet
Any plans on dashes for the early A bodies?
MikeR
I'd have to say no firm plans at this point, but we're looking at them. (early A's)
TimH
What type of material is the dashes made from. Steel, aluminum, plastic?
Tim
wickedfirefighter
oroville, ca
those are great looking dashes .. im defenitly gonna get one..
MikeR
The dashes are Aluminum.
TimH
Aluminum is cool. How thick? Are the round inserts pressed in or welded in? Do they need prep work to be painted or powder coated? (do the welds need dressing?)
Tim
MikeR
Let's see...The face is 1/8th inch aluminum, the tubes are welded to the back and conform to the shape of the face. We ship them either Powder Coated (black, gray or silver) or we sand them to remove tooling marks, we use a DA sander and 80 grit paper. Customers have polished them, Painted them, even put them in their car with the sanded finish (we don't recommend this unless they're clear coated.
Home this helps
TimH
Wow sounds like you guys put out a quality product! Doesn't the face warp from the welding? I take it they are welded from the back side only?
Tim
MikeR
how much is the powder coating for an a12?
and also how much would it cost to get an a12 without the light and wiper holes?
MikeR
The powder coating is $95.00, regardless of the size of the dash, and eliminating the light and wiper holes doesn't change the price....it's like not wanting pickles on your burger (you have to wait for them to make it special)
i would rather wait, because that way i get my burger strait off the grill, not one that has been sitting on a hot plate for 20 minutes
i am contemplating moving them down to the console i am making, just for something different, i am moving most things down there such as switches for a cleaner look, what size are those holes for the lights and wiper, i would like to keep my brake pressure light also
its all speculation, i am think off asking my parents for one for Christmas (or late Christmas) and paying for part of it
is 1DART440's dash sanded with a clear coat?
also, how in the heck do you get the stupid dash pad off, im stumped
Evan
also, how in the heck do you get the stupid dash pad off, im stumped  , i know what you mean. take out the dash insert, heater controls, and glove box. then you can reach in and take out the nuts that hold the dashpad to the dash. it helps to find somebody with skinny agile hands! i cant remember how many, maybe 7 or 8?
TimH
Does powder coating fill in the line (joint) around the tube where it meets the face? I know this sounds confusing. The tube goes through the panel and is welded from the back, so there would be a circular joint line on the face. I know powder coating is thick, but I was wondering if it actually fills in that line?
Tim
MikeR
There's no line to fill...the tube attaches to the back, it doesn't pass through. It's a very clean look.
I have one (not installed yet) and can tell you that the fitup is perfect before welding. There are some small welds on the back side. You have to look pretty hard to see the seam. The seam is not on the face, it's in the gauge tunnel.
does anyone have a pic from the back of their rocky-dash with gauges installed? the fronts are awesome, no doubt there, but Id just like to see how the gauges attach etc. and how youre wiring them up.
MikeR
The gauges attach with the mounting brackets that come with the gauges, the tubes are made to act as a surface mount, so that part is easy.
Wiring: you have to run a common Power, Common Ground, Light Power and I Grounded the lights separate from the gauge grounds, then each gauge has an individual wire for reading, like the fuel sender wire, tach wire...that sort of thing.
Evan
check out Crazy68Darts pictures in the gallery. he has pictures of the back of the dash installed.
Dave_n_68_383S
I dont have a picture of mine but think is sweet now matter how you cut it. Its a great product.
One thing I'm curious about.. Is there a way to get it to go deeper into the dash? Mine sort of sits in the front.. if that makes sense ?
MikeR
Dave, not sure what you're after...
wickedfirefighter
oroville, ca
has amyone got a glove box to work with a full length ... maybe cutting the dash and making the section that has been cut out the glove box cover ...
MikeR
We offer a glove box cover option with all full length dashes...for the pre 70 cars there's a hole for the glove box button and for the 70+ cars there's a bezel for the turn knob to fit in.
