December 05, 2008, 02:19:13 AM
| | |-+  Subframe connectors size?
Author Topic: Subframe connectors size?  (Read 1052 times)
BIG DOG
« on: August 31, 2006, 12:45:14 PM »
Is there a definite size to use for the subframe connectors? I see some use 3x3 x 1/8 some use 2x3 x 1/8
and some even use 1 1/2 3 x 1/8 .The 1 1/2 would fit up at the rear frame nice as none would have to be cut out there but it wouldn't go up on the frame much at the rear either also wouldn't tie into the floor.Good or bad to that I guess .I believe that I will use the 3x2 or are there better ways ? You could use a 2 1/2 x 2 1/2 then use a square channellthat would fit over the frame rail and over the 21/2x21/2 and weld that all in .
Please give me your thoughts!thanks.
Blair
1DART440
Re: Subframe connectors size?
« Reply #1 on: August 31, 2006, 03:50:51 PM »
I think the the 2x3x0.125 is best. The 3" works perfect for capping the rear rail and having the piece come up in the back floor ties things together well. Cutting the strip out of the floor isn't that much work if you have come this far.
« Reply #2 on: August 31, 2006, 04:33:36 PM »
arent there some weld-ins now that are laser cut to fit the floorpan and appear 'almost stock'?
anyone recall who makes those?
BIG DOG
« Reply #3 on: August 31, 2006, 04:41:23 PM »
Yes they are in the mags I think magnum force stuff.They would have to be butt welded along the floor. Would be nice if they were bent at the top and you could spot weld them on like the factory floor pans are.
Tom1951
« Reply #4 on: September 01, 2006, 01:44:03 AM »
I made mine from 3X2 but Comp Engineering, CA Chassis Works and Magnum Force all make them.
440 Scamp
« Reply #5 on: September 01, 2006, 01:43:39 PM »
I did it a slightly different way.  I used a 2x3" .125.  Instead of capping the rear rail, I cut into the floor, cut out the front face of the rear rail and slide the 2x3" inside the rail.  The 2x3 is slid about 10" inside the rear rail.  The 2x3 is welded all the way around the front face of the rear rail as well as several rosette welds using 1" holes drilled along the 10" over lap section.  It cuts into the floor pan a good bit, but to me that just ties it in that much better.  Just another option.  I tried to upload several pics but I think they're to big.  I can e-mail some if you like.
« Reply #6 on: September 01, 2006, 01:53:47 PM »
You mind sending me some pics?  mopowers2@yahoo.com
Thanks, I'd love to see that set-up.
mopar_man72
mopar+man+2004 mopar_man8596
« Reply #7 on: September 01, 2006, 03:48:08 PM »
I have a couple pieces 2 x 2 x 1/8 laying out back that used to be part of a weight bench.  they have 2x 5 x 1/4 plates welded to them.  how well will this work if I use the plates to gusset the tubing?  I've already used some of this steel to make a cargo platform for my reciver hitch, and it'll hold as much weight as anything ou can buy in the store.
73 Duster: 440 auto- for now!
2000 Dakota Sport: 3.9 auto 4x4
2006 Freightliner Columbia - my home away from home
mopar_man72
« Reply #8 on: September 01, 2006, 03:50:29 PM »
another view
A13Dart
Minnesota
« Reply #9 on: September 01, 2006, 09:21:06 PM »
NHRA rules limit the size to a maximum of  2x3x1/8, so don't go larger than that...ya might want to take it to the strip someday drag tree
mike.
farmington
Metro Detroit
« Reply #10 on: September 02, 2006, 12:21:02 AM »
I used 2 x 2 for my duster.  They still came through the floor, but only 1/4" to 1/2".  cant even tell under the carpet.  I got them from Auto Rust Technicians.  in Deleware, I believe. I'm very happy with them.
don
When in doubt, Whip it out!
« Reply #11 on: September 02, 2006, 02:30:10 AM »
A13Dart
were did you get this information regarding a maximum size for the connector dimensions?
thanks.
A13Dart
Minnesota
« Reply #12 on: September 02, 2006, 02:48:46 PM »
I just realized I was looking in the NHRA rulebook in the stock/super stock section for subframe connectors. The other sections of the rulebook don't really have any specs on the size. Sorry for any confusion Embarrassed
mike.
« Reply #13 on: September 03, 2006, 12:16:08 AM »
BIG DOG
« Reply #14 on: September 03, 2006, 09:36:58 PM »
I see some have a plate welded on the end of them then they weld around the plate to the front cross member. What is the advatage to this as opposed to just welding it to the cross member?
Also could you do your cut out for the rear spring relocation fit the relocation box in so that was correct.Then fit the tubing for the frame connectors.Get them so that they would both fit .Then tack them together then install as one peice and then weld in ...Seperate or together what I'm getting at I guess is why not make it as one complete peice from the front crossmember right out the rear tiying the relocation box and the subframe connector together?
55robert@comcast.net
« Reply #15 on: September 04, 2006, 12:58:35 AM »
sounds like a great idea.
mopar_man72
« Reply #16 on: September 04, 2006, 10:21:03 PM »
any harm in welding in frame connecters w/ out the engine in the car?  I haven't gotten my block back from the machine shop yet......might not get it put together for a while.  If I don't weld continuously on one side what are the odds of twisting the body?
« Reply #17 on: September 04, 2006, 11:19:32 PM »
You will be fine. I welded mine with the rear end up off the deck and the front sitting on its suspension. I just checked the body gaps and the doors shut good.
74DDS
Lakeville/Mankato, Mn
« Reply #18 on: October 02, 2006, 01:43:06 AM »
Now how did you support the car? jack stands under the axle in back then what up front? Becuse don't you have to have all the weight on the suspension to have it he straightest?
