December 02, 2008, 03:52:31 PM
| | |-+  65, Dart Steering column
Author Topic: 65, Dart Steering column  (Read 253 times)
Mopartist
« on: September 05, 2006, 03:54:14 PM »
I'm out of ideas on how to get the steering column out of my Dart so I can clean it up and take the column shift lever off. Any advice would be appreciated. Is the pin in the end pressed in? My Dart/Coronet manual doesn't cover it.
ski
Re: 65, Dart Steering column
« Reply #1 on: September 05, 2006, 04:36:20 PM »
I'm pretty sure it only comes out one way.  Try a good deep socket that just fits over the pin and a big C clamp.
Mopartist
« Reply #2 on: September 05, 2006, 04:45:16 PM »
Good idea! I'll give it a shot Wink Thanks!
Modified later........Welp; no luck. I have it soaking in "liquid wrench". I don't want to heat it up with a torch because of the rubber seal just a couple of inches from there. When I see how the new connector attaches; I'll be able to assess if i can "mar" the pin up or not with vise grips.
ski
« Reply #3 on: September 05, 2006, 05:29:34 PM »
Did you try to press it out both ways?
Mopartist
« Reply #4 on: September 05, 2006, 05:43:05 PM »
Yep; It's as tight as if it's been in there since 1965! Grin
Mopartist
« Reply #5 on: September 06, 2006, 04:07:51 PM »
OK; Boy is my face red! I feel so dumb about this; but I admit it. I overlooked the obvious. I was absolutely sure I had all the bolts out on the column plate; (which is bolted to the firewall )but in my rush to remove the column; I didn't see two of the plate mounting bolts. (It's dark under a dash) So; I was sure that the pin in the other end had to come out in order to remove the column. ......DUH!
 \/][ hammer
(I'm glad I didn't cut it out.....derrrrrrrr.... Embarrassed)
I dunno about some of you guys; but it seems the older I get; the denser I get. Gosh; whats gonna happen in 20 years?
