July 24, 2008, 01:18:12 AM
| | |-+  Mopar sender for electronic speedo
Author Topic: Mopar sender for electronic speedo  (Read 678 times)
1DART440
« on: September 06, 2006, 09:58:49 PM »
I just thought I would post the part number of the Mopar sender that I used for my electronic speedometer. It is 1-05252438. This unit is a 2 wire type and I used it with a VDO speedometer. This unit threaded right on the old 727 and gave me 8327 pulses per mile (40 tooth gear, 3.91 gear & 26.7" tires). I can help with any connection info that anyone might need.
blasterboy
Re: Mopar sender for electronic speedo
« Reply #1 on: September 13, 2006, 03:44:32 PM »
what is that sender out of?   it should also bolt on a 833 correct?  thanks for info this is what makes this and other boards work.  blasterboy
1DART440
« Reply #2 on: September 13, 2006, 09:15:55 PM »
I'm not sure what it is out of, sorry. I think any newer stuff that uses a big tranny. It will go on the 833, same speedo gear assembly as the 727.
67 dartgts
Go fast or go Home
« Reply #3 on: September 13, 2006, 09:22:18 PM »
Hello Terry,
Did you order the speedo sender from your dealer??  Oh by the way i ordered my solid lifter cam today ...no hydrralic lifters for me next season.
LOL
  Maynard
1DART440
« Reply #4 on: September 13, 2006, 09:37:01 PM »
Hi Maynard.
I just walked to the parts counter at the local dealership and asked for whatever senders they had in stock. The guy pulled this one out  and I threaded it on the gear assembly, done deal. I checked it with an ohm meter and it make 8 contact closures per rev, perfect! On my speedo it switches the pulse input terminal to ground. The VDO speedo has a pull-up resistor (internal) to 12V. It works great. I had a 92 Jeep and I think this is the same sensor, 92 was long ago and my memory is not as good anymore.
I haven't gone anything with my lifters.  I'm just going to drive the car a little more and then pull the motor and tranny before I store it for the winter. Full tear-down and inspect, maybe eddy heads! Winter come fast up here in Canada Sad
Terry
caper
Cape Breton , Nova Scotia
« Reply #5 on: September 13, 2006, 10:06:57 PM »
I just got one out off a van . I think anything that has a 904 trans.
1967dart406
CHARLESTON, SC
« Reply #6 on: September 14, 2006, 11:22:35 AM »
it fits a 90 or so model truck and some jeeps
