Topic: Mopar sender for electronic speedo (Read 663 times)
1DART440
I just thought I would post the part number of the Mopar sender that I used for my electronic speedometer. It is 1-05252438. This unit is a 2 wire type and I used it with a VDO speedometer. This unit threaded right on the old 727 and gave me 8327 pulses per mile (40 tooth gear, 3.91 gear & 26.7" tires). I can help with any connection info that anyone might need.
blasterboy
what is that sender out of? it should also bolt on a 833 correct? thanks for info this is what makes this and other boards work. blasterboy
1DART440
I'm not sure what it is out of, sorry. I think any newer stuff that uses a big tranny. It will go on the 833, same speedo gear assembly as the 727.
67 dartgts
Hello Terry, Did you order the speedo sender from your dealer?? Oh by the way i ordered my solid lifter cam today ...no hydrralic lifters for me next season.  Maynard
1DART440
Hi Maynard. I just walked to the parts counter at the local dealership and asked for whatever senders they had in stock. The guy pulled this one out and I threaded it on the gear assembly, done deal. I checked it with an ohm meter and it make 8 contact closures per rev, perfect! On my speedo it switches the pulse input terminal to ground. The VDO speedo has a pull-up resistor (internal) to 12V. It works great. I had a 92 Jeep and I think this is the same sensor, 92 was long ago and my memory is not as good anymore. I haven't gone anything with my lifters. I'm just going to drive the car a little more and then pull the motor and tranny before I store it for the winter. Full tear-down and inspect, maybe eddy heads! Winter come fast up here in Canada  Terry
caper
I just got one out off a van . I think anything that has a 904 trans.
1967dart406
it fits a 90 or so model truck and some jeeps
