Topic: g machine kit (Read 876 times)
jackstands
i have a 69 dart and am about to rebuild the suspension and switch to disk brakes. I think i am going to go with the "G machine" stage II kit. Would i buy the one for disk brakes or the one for drum brakes and ask for the 1973 lower balljoints? Thanks for the help
G-machine Stage II ? This is a kit from someone?
PST I think.
jackstands
Scampin
Thats alot of money for a bushing kit. It doesn't even come with a swaybar? What are you actually getting for 1000bucks?
jackstands
i just copied and pasted this STAGE II KIT Includes: Complete Graphite Impregnated Polyurethane Front End Rebuild Kit :: Front & Rear KYB Gas Charged Shocks or Struts :: Front & Rear Powder Coated G-TECH Sway Bars with Polyurethane Bushings :: Front & Rear Springs (Coil or Leaf) NOTE: No Rear Springs on MOPAR & Corvette :: Polyurethane Leaf Spring Bushings & Pads (where applicable) :: Rear Trailing Arm Bushings (where applicable) • MOPAR Torsion Bars, Boots & Clips
It has sway bars. Probably not a bad price, but there are problems with using the poly LCA bushings.
mrspeeddemon
I have a PST kit and they give you a stock style rubber lower control arm bushing- they even say the aftermarket poly ones are junk!
jackstands
what should i do? this is my first project car ever! what have you guys done?
Scampin
MOPAR "A" Body-1963-66 • $881.75* ** Dart, Duster, Demon, Valiant *NOTE: No Front Sway Bar included. MOPAR "A" Body 1967 Only • $1111.70** MOPAR "A" Body 68-72 Drums • $1031.70** MOPAR "A" Body 68-72 Discs • $1011.70** MOPAR "A" Body 73-76 • $931.70**
It says it doesn't come with a front swaybar. So it doesn't come with a front swaybar or rear springs? Not really arguing with anybody, just that I am in the market also and am trying to cover all my bases on parts aval.
It's only the early (66-earlier) kits that doesn't have a front sway bar because they don't have one available.
DartKnight
What's wrong with the poly lower bushings?
Jason
jackstands
well heres what i did. I bought Billy Reillys upper control arms, KYb shocks, .990 torsion bars from Mancini, Schumacher mounts, and a Super polygraphite front end rebuild kit from PST. I hope that works out, it doesnt have sway bars but shouldnt be too bad for my first car
mrspeeddemon
from what I understood from PST is that poly LCA bushings don't use an outer sleeve in the design giving them nothing to really hold them in place- you actually have to use the old sleeve? I think? I'm not an expert but thats what I gathered from a couple different places.
dmn71
Coal Valley, Illinois
mrspeeddemon's right. I'm going through front end rebuild right now and with all rubber and with poly you have to use old sleeve. Steve
slow_motion
i'd still use a stock rubber bushing in the lower arm and i'd definatly get some sort of front sway bay.
--chad
Formerly: 400dart, 4523 posts on old board. Recovering racing addict and turbo junkie
'85 D150 stepside, lowered, magnum 360 '96 Dakota,3.9, 2" drop, GenIII wheels '95 Ram, her truck '71 Duster, her car, 318/air, stock '20 Model T pickup, stock
I agree with Chad - use a rubber lower arm bushing - the rest would be ok, but that one would be much better as rubber. As for a bar, it's a good idea, but it's just an add-on that you could do any time, so no worries on that piece.
