November 22, 2008, 02:39:23 AM
| | |-+  B-Body Rotors on K-H spindles
Author Topic: B-Body Rotors on K-H spindles  (Read 198 times)
Frank
« on: September 14, 2006, 09:21:35 AM »
I was reading Tom Condran's book (Performance Handling for Classic Mopars) and on Page 5 he writes:
Quote
Regrettably, '65-72 rotors can not have the stud pattern re-sized to the large 4½" pattern common to other Mopars.  There is no "meat" where the machinist would drill.  And outside diameters of the hubs (which center wheels) match only small bolt-pattern wheels.
The bolt pattern can be up-sized only by swapping on rotors from a '66-69 B-Body, if you can find two of those rarities in good condition.  These Bendix rotors - and not the calipers from that system - match A-Body knuckles and calipers as if they were built for them.  They even share wheel bearings.
I see that Layson's Restorations and the Paddock carry a unicast (combined hub & rotor) version of this rotor.  Has anyone tried this B-Body rotor on their A-Body K-H disc brakes?  Does anyone know which company manufactures this rotor for Layson's or who else carries this rotor?
Frank
Bogie
Bogie7177@Hotmail.com Bogie7177 Bogie7177
Re: B-Body Rotors on K-H spindles
« Reply #1 on: September 18, 2006, 03:43:27 AM »
I have nothing to add but I have been trying to figure out (no hard thou) how to go to large bolt pattern using the KH brakes as the only reason I didnt do the entire swap was that my car has a good working disc system. But if I could just swap rotors & the axles (and other items) out back I would go to large Bolt
66 Dart 170 2 door Sedan 273 HP,A833,8 3/4 W/3.90's, Front Disc,Radio Delete
84 W350 1 Ton Crew Cab 360.NP435,D60's W/4.10's,9" Lift,37" SSR's
