February 08, 2010, 06:29:32 PM
| | |-+  kickdown linkage info needed
Author Topic: kickdown linkage info needed  (Read 280 times)
grudd440
« on: May 28, 2009, 10:47:00 PM »
I have some questions regarding the kickdown lever on a 727 trans.  Huh If u dont have a kickdown linkage from the carb and want to lock it 2/3 open, would that be 2/3 forward(facing front of car), or the opposite way? My other ? is, my kickdown shaft doesnt have a lever on it, but it seems like when i move it by hand it is loose , like by moving it it doesnt feel it isnt connected to anything.   Also too, by not having it hooked up can this cause a trans to slip?  thank u.
440 DusterDemon
west
Re: kickdown linkage info needed
« Reply #1 on: May 28, 2009, 10:54:06 PM »
the lever pushes towards the rear of car when the accelerator is pushed.
FIX IT
you will fry your trans,even with it rigged 2/3 of the way open
12.7 on street tires
warrenton, north carolina
« Reply #2 on: May 29, 2009, 08:11:08 AM »
lokar makes a flexible cable kickdown.
CudaDon65
« Reply #3 on: May 30, 2009, 05:07:19 PM »
Hi this is the setup I used..car is not finished but I like the way it works. www.bouchillonperformance.com.
