I'm back, and so is my 68 Dart.
Page 1 of 10 1 2 3 ... LastLast
Results 1 to 20 of 196
Thread: I'm back, and so is my 68 Dart.
  1. #1
    BBD LEGEND
    Join Date
    Jan 2007
    Location
    DFW TX
    Posts
    2,148
    Post Thanks / Like
    Its been a while since I have been here, I have been working a lot, and traveling even more, but after a three month absence, I started working on the Dart again a few weeks ago. Here is the latest progress.
    Hidden Content <br /> <br /><br />Hidden Content
  2. Remove Advertisements
    BigBlockDart.com
    Advertisements
  3. #2
    Super Moderator bremereric's Avatar
    Join Date
    Dec 2009
    Location
    Tomball, TX USA
    Posts
    3,885
    Post Thanks / Like
    Looks good with those wide tires...not tubbed yet? Just have the inner fenderwell cut out in the back?
    Eric Bremer
    Tomball TX 77375
    1968 Dodge Dart 440 Big Block, Edelbrock Performer RPM Heads, Performer RPM intake, Holley 770 CFM Street Avenger, .541/.538 lift hydraulic roller cam, Harland Sharp 1.6 Ratio Roller Rockers..Crane Roller lifters..580 Final lift, MSD pro-billet distributor, MSD ignition, 355 Auburn Suregrip 8 3/4 rear end.
    Hidden Content
    1977 Dodge Aspen R/T...318...4 speed tranny with 355 gears in a 8 1/4" rear.
  4. #3
    Senior Member 68fish's Avatar
    Join Date
    May 2007
    Posts
    610
    Post Thanks / Like
    Long time no see Fly. Glad you're back. Darts lookin' good. Whats the plan for the wheel tubs? Spring relocation?
    http://i245.photobucket.com/albums/gg53/jdavenport6/b-25011.jpg
  5. Remove Advertisements
    BigBlockDart.com
    Advertisements
  6. #4
    BBD LEGEND
    Join Date
    Jan 2007
    Location
    DFW TX
    Posts
    2,148
    Post Thanks / Like
    Both minitub and relocation, finishing it up this weekend. Had to buy some tools this morning, plumb bob, level, 4ft straight edge, welding blankets, and an angle finder. Does anyone know how much S/S springs will sag when the car is on the ground? I am going to guess at 1"
  7. #5
    BBD LEGEND
    Join Date
    Jan 2007
    Location
    DFW TX
    Posts
    2,148
    Post Thanks / Like
    I am also buttoning up the engine this weekend too, finally got the last part, pushrods.
  8. #6
    Join Date
    Jun 2007
    Posts
    322
    Post Thanks / Like
    Hey Flyboy...Looks nice. I'll be doing the minitub/ relocate thing soon enough.
    Hidden Content Life begins @ W.O.T!! A.K.A. GTSCowboy Hidden Content
  9. #7
    Senior Member CudaDon65's Avatar
    Join Date
    Apr 2006
    Posts
    681
    Post Thanks / Like
    Hey fly, glad your back at it..Keep the pics and info coming.
  10. #8
    Senior Member buck440's Avatar
    Join Date
    Mar 2009
    Posts
    737
    Post Thanks / Like
    lookin good
  11. #9
    BBD LEGEND
    Join Date
    Jan 2007
    Location
    DFW TX
    Posts
    2,148
    Post Thanks / Like
    I have finally finished the mini-tub / spring relocation, I am now working on the rearend, installing a 4.56 LS 742. Wow, that was a shitload of welding! I still need to seam seal and undercoat the wheelwells, here are some more pictures, I have some more up-to-date pictures I still need to download off the camera later tonight.
  12. #10
    Join Date
    May 2007
    Posts
    610
    Post Thanks / Like
    That looks great. I'm glad you posted these pic's cause the Tech Section is down and that was the only reference I had. I'd appreciate it if you could post any others. It'll help out a lot when I do mine.
  13. #11
    BBD LEGEND
    Join Date
    Jan 2007
    Location
    DFW TX
    Posts
    2,148
    Post Thanks / Like
    All I can say, i way underestimated the amount of time it would take to do the minitubs and relocation! It was a lot of work and welding, but it was worth it, and relatively cheap too. About $200 in materials to mini tub and relocate the springs.
  14. #12
    Join Date
    Dec 2009
    Location
    Tomball, TX USA
    Posts
    3,885
    Post Thanks / Like
    Quote Originally Posted by flyboy01 View Post
    Are you going to box in the part of the frame rail you cut out where the springs are going to be relocated...
    Eric Bremer
    Tomball TX 77375
    Hidden Content
  15. #13
    Full Member demon1515's Avatar
    Join Date
    Jan 2010
    Location
    Dirty South ATL GA!
    Posts
    206
    Post Thanks / Like
    Nice, what gauge of sheetmetal did you use for the minitubbing?
  16. #14
    Join Date
    May 2007
    Posts
    610
    Post Thanks / Like
    About how many hours you think you've got into the job? I think the old Tech section put it at about ten hours per side.
  17. #15
    BBD LEGEND
    Join Date
    Jan 2007
    Location
    DFW TX
    Posts
    2,148
    Post Thanks / Like
  18. #16
    BBD LEGEND
    Join Date
    Jan 2007
    Location
    DFW TX
    Posts
    2,148
    Post Thanks / Like
    Quote Originally Posted by demon1515 View Post
    I ended up using 22 gauge, it was pretty close to the metal in the factory wheel well, maybe 20, but definately not 18.
  19. #17
    BBD LEGEND
    Join Date
    Jan 2007
    Location
    DFW TX
    Posts
    2,148
    Post Thanks / Like
    Quote Originally Posted by bremereric View Post
    I'm not sure I understand your question? What more would I need to box?
  20. #18
    Join Date
    Dec 2009
    Location
    Tomball, TX USA
    Posts
    3,885
    Post Thanks / Like
    The last picture you posted answered my question...see when you welded in into the frame rail how it looks boxed in now.....what are you running in your 742 pumpkin....it's also a good idea to box in your leaf spring perches...bend some metal around the tube and weld it to the sides of the spring perches and the axle tubes....everything looks really good..
    Eric Bremer
    Tomball TX 77375
    Hidden Content
  21. #19
    BBD LEGEND
    Join Date
    Jan 2007
    Location
    DFW TX
    Posts
    2,148
    Post Thanks / Like
    Quote Originally Posted by 68fish View Post
    I have about 4 hrs in the spring relocation with the Mancini spring boxes, and about 20 hrs with the wheeltubs. If you have never done it before, you will spend a lot of time thinking about where to cut and how to re-attach the tubs. I probably saved a bit of time figuring out the filler strips with cardboard.
    It was hard trying to figure out where is the best place to cut the boxes, There are some reference points even on both sides (see pic)
  22. #20
    BBD LEGEND
    Join Date
    Jan 2007
    Location
    DFW TX
    Posts
    2,148
    Post Thanks / Like
    Its a 4.56 LS 742 rear
Posting Permissions
  • You may not post replies
  • You may not edit your posts
