Here's some pic's for you guys that want to Modify for block for better oiling. Mopars main oil gallery is roughly a 9/16 bore all the way thru the block on both sides. The bad deal is every lifter passes thru each gallery meaning, you have 16 points of leakage, not including a massive leak in the # 4 main, which feds #4 cam journal, which is timed, to feed each rockershaft assy. All the holes in this late 77 440 block were a 1/4, these are the feed holes that come down from the passenger "Main" oil gallery. As you can see in the pic, #2, #3, #4, #5, are fed off of the main oil gallery. #1 is fed off the front which intersects the pass over passage that is cast into the front of the block from the oil pump pad.
