Rear Mount Turbo!
Results 1 to 13 of 13
Thread: Rear Mount Turbo!
  1. #1
    Junior Member rdakota340's Avatar
    Join Date
    Apr 2006
    Posts
    80
    Post Thanks / Like
    Rear Mount Turbo!
    Been working on it for 4 years just started driving it things to do tune it,front end alignment drive it some more!
    https://www.youtube.com/watch?v=vy-w...ature=youtu.be
    Turbo Addicted!
    Blow throughs work!
  2. Remove Advertisements
    BigBlockDart.com
    Advertisements
  3. #2
    Full Member downtime!'s Avatar
    Join Date
    Mar 2013
    Location
    Keller, TX
    Posts
    136
    Post Thanks / Like
    Seriously cool car man! Looking forward to seeing some numbers on her.
  4. #3
    Join Date
    Apr 2006
    Posts
    80
    Post Thanks / Like
    Thanks its been fun for sure!
    Turbo Addicted!
    Blow throughs work!
  5. Remove Advertisements
    BigBlockDart.com
    Advertisements
  6. #4
    Join Date
    Mar 2008
    Location
    San Diego
    Posts
    382
    Post Thanks / Like
    Does it take longer for the turbo to provide boost with it further away from the intake? Just wondering if there is some lag. Great way to add a turbo without squeezing it in under the hood.
  7. #5
    Newb
    Join Date
    Nov 2013
    Location
    Maryland
    Posts
    24
    Post Thanks / Like
    Car looks great! I'm planning the same thing with twins.
    You really got that turbo tucked up nice.
    Please take some pictures underneath where you ran the pressure side back up front.
    I'm sure you will draw a lot of looks for your "missing" tailpipe!
    500 Low Deck Hemi, Stage V aluminum heads, Twin Turbo, Megasquirt, 4L80, Dana60.
  8. #6
    Join Date
    Apr 2006
    Posts
    80
    Post Thanks / Like
    Thanks guys believe it are not the couple of local meets people have looked for the breather LOL hope these pics help you out I did have a big round inline A/W inter cooler but I took it off I'm putting a meth injection system on I got the BFPV pump installed next is injection on then get him to the dyno!
    Turbo Addicted!
    Blow throughs work!
  9. #7
    Newb
    Join Date
    Nov 2013
    Location
    Maryland
    Posts
    24
    Post Thanks / Like
    Thanks for the pics!
    Nice job with the plumbing.
    No feeling like when the boost comes on!
  10. #8
    Senior Member
    Join Date
    Feb 2007
    Posts
    574
    Post Thanks / Like
    Most turbo's have a gravity feed back for the oil drain, as yours is way in back and sits so low, I would think the oil return would have a certain amount of pressure in it. In the truck industry that could relate to oil leaking past the shaft seal and getting into the intake (compressor side) of the syst. Do you have trouble with this?
    69 Swinger 340
    Soon to be 69 426 Dart
    80 Crew Cab gas hawg
    01 DIESEL Hauler
      Bailey, Colorado
  11. #9
    Senior Member cu440da's Avatar
    Join Date
    Dec 2005
    Location
    Cottage Grove, MN
    Posts
    792
    Post Thanks / Like
    Turbos mounted like his that cant use gravity to return oil to the pan have a sump for the turbo and its own pump to get the oil back up to the motor.
    How loud is the exhaust with your setup? I have heard a lot of guys running turbos dont even use mufflers. Just curious as it seems there would still be quite a bit of sound energy in the exhaust.
    '78 Warlock- 5.7 Hemi/Viper T56
    '05 Magnum RT 5.7
    '96 F150 Supercab 4x4
    '03 Kawasaki Z1000
  12. #10
    Senior Member
    Join Date
    Feb 2007
    Posts
    574
    Post Thanks / Like
    Quote Originally Posted by cu440da View Post
    With something like an electric pump for the return oil??
    69 Swinger 340
    01 DIESEL Hauler
      Bailey, Colorado
  13. #11
    Join Date
    Dec 2005
    Location
    Cottage Grove, MN
    Posts
    792
    Post Thanks / Like
    Exactly.
    '05 Magnum RT 5.7
    '03 Kawasaki Z1000
  14. #12
    Join Date
    Dec 2005
    Location
    MONTGOMERY COUNTY MARYLAND
    Posts
    376
    Post Thanks / Like
    i like it
  15. #13
    Newb
    Join Date
    Nov 2020
    Posts
    5
    Post Thanks / Like
Posting Permissions
  • You may not post replies
  • You may not edit your posts
