I think it would be great info if some of us could list our specs of our cars. List as much info as you can. Other people could see what it takes to get a car to a specific et. My book with specs is at my shop. But here is some info!! 505 cu. in. - 440 block, no filler, no girdle, steel billet main caps, bored .030" , Callis 4.250" crank, Oliver steel rods chevy size, JE pistons, little over 14 to 1 compression, Brodix B1-BS heads, ported , Crower solid cam around .609" and .599" lift, duration?, custom built step headers 1-3/4" to 1-7/8" to 2" with merge collectors, M1 intake with 850 dp Holly , #92 square jetting, no power valves, double roller timing chain, 35*full timing, FBO ignition system ( no MSD), BG400 ful pump, Shogun water pump and water manifold, custom built BeeCool radiator, shroud and catch can, #8 or #10 radiator hoses, CRT 727 super/pro2 transmission (rollerized, billet aluminium front drum, bolt in sprag, Griner billet valvebody, transbrake) ,Hurst 1/4 stick shifter, with air shifter, PTC 8" converter, flashes to 5300-5400 rpm, shift at 6100 rpm, cross traps at 6300 - 6400 rpm , 4.10 gears in Ford 9" rear, Mark Williams axles, ladder bar with coil over rear suspension, Alston chassis 2"x3" box frame, coil over front suspension, rack & pinion steering , Wilwood 4 wheel disc brakes. Hoosier 32" x 13.5"w x 15" . Car weghs 2550 , 2730 with driver. 9.458et, 141.35mph, 1.278 - 60 foot,
