1978 Volare
Results 1 to 4 of 4
Thread: 1978 Volare
  1. #1
    Join Date
    May 2009
    Posts
    181
    Post Thanks / Like
    1978 Volare
    Picked up this beater a couple weeks ago for my daily driver. One of the issues is it has a very quick squeal/chirp when it shifts into 2nd, and a quick chirp on startup. The 1-2 shift is pretty firm, which I don't mind, except for the annoying squeal. The 2-3 shift feels perfect. I put new gates belts on, they made no difference. I would rather not use a belt dressing, but rather figure out what is causing it. Its almost like the trans is shifting so fast, the belts cant keep up for that split second. Just looking for ideas or suggestions. Its a 225/904. I'll try posting a pic.
  2. Remove Advertisements
    BigBlockDart.com
    Advertisements
  3. #2
    Full Member 70spaceduster383's Avatar
    Join Date
    Jun 2010
    Location
    New Mexico
    Posts
    147
    Post Thanks / Like
    If you think it's the belt, take the belt off and with the engine cold take it for a quick test drive.
  4. #3
    Newb
    Join Date
    Aug 2014
    Location
    Kansas City, KS
    Posts
    8
    Post Thanks / Like
    You might try some rough sandpaper on the inside of the grooves of the pulleys, to give the pulleys some texture, and give the belts something to grip.
  5. Remove Advertisements
    BigBlockDart.com
    Advertisements
  6. #4
    Join Date
    May 2009
    Posts
    181
    Post Thanks / Like
    I just swapped belts and didn't bother to even look at the pulleys.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
