Tubular Suspension
Results 1 to 14 of 14
Thread: Tubular Suspension
  1. #1
    Newb
    Join Date
    Aug 2014
    Location
    indiana
    Posts
    7
    Post Thanks / Like
    Tubular Suspension
    Picked this up at Mopar Nationals Saturday. I spent some time checking out the tubular k frame kits offered by a few companies. I've heard good things about a relatively unheard off company out of Iowa called Gerst Tubular Suspensions. Ended up with a Gerst Tubular Suspension.
    So far, everyone I talked to personally that has one and is running one, can find nothing negative to say. There are even some circle track and road race cars running this thing, talked to one of the owners/drivers over the weeked, nothing but rave reviews about it.
    Thoughts so far, will update on install.
    This thing is built stout, I'd mount it on a tank. And he's proud of it. Said that if you can find a stronger unit, let him know, he'll make it even stronger.
    Full IFS coil overs, Shocks are dual adjusting.
    Ball joints are rebuildable and maintainable QA1 units. Very nice
    TIG welded and man do the welds look amazing.
    I compared all 3 that I saw at the nats, RMS, HDK and GTS. All had similarities, all had differences. To me, its about building a better mouse trap. That's pretty much what the after market is about. Improving on what is already out there. Here's why I chose the kit over the others:
    A: It didn't use the factory shock towers like the HDK. I know HDK rienforces the towers in their kit, which I'm sure does work just fine. But it's not something I wanted ultimately
    B: It uses stronger and thicker steel than the others, granted it weighs a tad more than the others, but it appears stronger. It's also got more gussests than the others I saw as well. RMS is at 3/16th steel, GTS is 1/4, not sure on the HDK to be honest.
    C: No drilling the frame. Only cutting required is to remove the bump stops.
    D: Construction. The welds look AMAZING. again, everything is designed to improve factory caster/camber specs, lowers and uppers are designed to eliminate the caster/camber issues with the factory. Plus fully adjustable. Lower control arms are double shear, 2 cross bars, bucket style lower control arms, all of which are unique to this kit.
    E: Bang for the buck. Price is way less than the RMS and even the HDK, even if you go high end on the brake kits. There are a couple cheaper kits out there, but I saw their quality and it sucks. Ultimately, this is to me, the best bang for the buck.
    If you're in the market for a tubular suspension kit, look up Gerst. You wont be disappointed. Plus, its almost half of an RMS and cheaper than a Hemidenny as well.
    3300 plus shipping for a basic kit with stock style brakes and a manual rack. you can upgrade from there to power steering, wilwood, sway bar etc.
    I opted for no brakes since I have a set of mustang 2 brakes in the shop from my dad's project. A kit like mine is 3050 plus shipping. Course bare, non powdercoated may be even cheaper than that.
    Comparison: All data off respective company's websites and or flyers. Prices may have changed or whatever but this is the most recent i could find.
    RMS ALterkation = with brakes: 5600 plus shipping without brakes: 4995.00 plus shipping
    HDK= bare kit, no powder coatingno brakes, no spindels, no rack, no coil overs: 2800, add 100 for the rack, plus 600 in brakes plus 600 in coilovers, plus the spindels (price not listed on their website for spindels, so i didnt include that): 4100 plus shipping
    GTS: Basic kit, everything but the brake kit. = 3050, basic kit with stock style brakes, 3300 plus shipping. The GTS kit comes with QA1 rebuildable and adjustable tension ball joints, viking dual adjustable coil overs and springs. Manual rack(upgradable to power), mustang 2 spindels, upper, lower control arms.
    800 cheaper than the HDK and complete. and 2300 cheaper than RMS.
  2. Remove Advertisements
    BigBlockDart.com
    Advertisements
  3. #2
    Newb
    Join Date
    Jun 2015
    Location
    Willis, TX
    Posts
    2
    Post Thanks / Like
    web site
    I couldn't find a web site for Gerst or GTS. Do you know if they have one?
  4. #3
    Full Member Bigdummy's Avatar
    Join Date
    Dec 2006
    Location
    Cleburne,Tx
    Posts
    165
    Post Thanks / Like
    Far out !now I want one. I've been looking at Magnumforce
  5. Remove Advertisements
    BigBlockDart.com
    Advertisements
  6. #4
    Senior Member
    Join Date
    Dec 2011
    Posts
    656
    Post Thanks / Like
    That looks a lot like my alterK
    69 dodge Dart GT. 440. 950 carb. Auto with RPVB & GVOD. Dana w/4.56 gears. MSD Digital 6. TTI 2" headers. 3" exhaust. Peak Dash.
  7. #5
    Newb
    Join Date
    Aug 2014
    Location
    indiana
    Posts
    7
    Post Thanks / Like
    Quote Originally Posted by wwsmith View Post
    I spoke with Carl, the owner, the website is supposed to be launched anytime, when it is, ill let everyone know.
  8. #6
    Newb
    Join Date
    Aug 2014
    Location
    indiana
    Posts
    7
    Post Thanks / Like
    Quote Originally Posted by roccodart446 View Post
    There is a couple similarities but a lot of differences, one being its fully adjustable. Pull the alterkation photos up side by side and you can see the differences easier.
  9. #7
    Newb
    Join Date
    Aug 2014
    Location
    indiana
    Posts
    7
    Post Thanks / Like
    Quote Originally Posted by Bigdummy View Post
    I looked at them as well but heard very bad things, so I didn't go with them.
  10. #8
    Senior Member
    Join Date
    Dec 2011
    Posts
    656
    Post Thanks / Like
    Quote Originally Posted by csmopar View Post
    The issue with the Magnumforce is the location of the rack. They don't return properly when steering.
  11. #9
    BBD GOD
    Join Date
    Jan 2006
    Location
    warrenton , nc 27589
    Posts
    4,105
    Post Thanks / Like
    Thumbs down
    don't bother with it.
    "bOb Built" (no matter how many times it takes) Hidden Content
  12. #10
    Newb
    Join Date
    Aug 2014
    Location
    indiana
    Posts
    7
    Post Thanks / Like
    looks like GTS has their webpage up and running.
    www.gerstsuspensions.com
  13. #11
    Newb
    Join Date
    Jun 2019
    Posts
    6
    Post Thanks / Like
    Gerst tubular front k frame
    Just went to the web site and priced out the k frame for my 1968 Dodge Dart. I like the idea of having a rack and pinion power steering, disk brakes and the elimination of the torsion bars. But the 5000.00 dollar price tag is not in the budget this year. I will look around and see if I can find a cheaper alternative or the car will have to wait till the money gets better.
  14. #12
    BBD LEGEND Capt_Jack's Avatar
    Join Date
    Apr 2006
    Location
    Posts
    1,333
    Post Thanks / Like
    which sites did you look at?
    sadly, I know the feeling on budgeting. Id love to do the same to mine
  15. #13
    Newb
    Join Date
    Jun 2019
    Posts
    6
    Post Thanks / Like
    I looked at Gerst.
    Again I am very pleased with what I see. the high cost is a pain. If I could figure a way to finance it I would probably do it that way.
  16. #14
    Join Date
    Jan 2012
    Location
    okla
    Posts
    114
    Post Thanks / Like
    tubular front ends
    weired , mine does !
Posting Permissions
  • You may not post replies
  • You may not edit your posts
