Header options with tubular k & coilovers?
Results 1 to 8 of 8
Thread: Header options with tubular k & coilovers?
  1. #1
    Newb
    Join Date
    Jul 2009
    Location
    LAGRANGE, NC
    Posts
    6
    Post Thanks / Like
    I have a '73 Dart and want to install a stroked 400 & tubular k with coilovers and am curious what headers will work? Would like to use a more affordable offering for possibly a B/E Body ( 1 7/8") but not sure they'll fit without issues? I'll get a coated set and I'd like to avoid "modifying" them with a ball peen. Any help or input is appreciated.
  2. Remove Advertisements
    BigBlockDart.com
    Advertisements
  3. #2
    BBD LEGEND Capt_Jack's Avatar
    Join Date
    Apr 2006
    Location
    Posts
    1,344
    Post Thanks / Like
    I'd start by contacting the K manufacturer and getting their recommendations for exhaust. anything more without seeing and measuring, would be guesswork. guessing can get expensive quick.
    my two cents
  4. #3
    Newb
    Join Date
    Jul 2009
    Location
    LAGRANGE, NC
    Posts
    6
    Post Thanks / Like
    Quote Originally Posted by Capt_Jack View Post
    my two cents
    .....just seeing what others have used. I often value the opinion/experience of someone using a product more than a manufacturer's recommendation. Thanks.
  5. Remove Advertisements
    BigBlockDart.com
    Advertisements
  6. #4
    BBD LEGEND qkcuda's Avatar
    Join Date
    Dec 2005
    Location
    Caledonia, Ontario, Canada
    Posts
    1,846
    Post Thanks / Like
    Will it be using a stock steering box and linkage or a rack and pinion?
  7. #5
    Newb
    Join Date
    Jul 2009
    Location
    LAGRANGE, NC
    Posts
    6
    Post Thanks / Like
    Quote Originally Posted by qkcuda View Post
    Rack and pinion. Sorry for the delay. I don't check back very often because I rarely get any/many responses on this site.
  8. #6
    Join Date
    Dec 2005
    Location
    Posts
    1,846
    Post Thanks / Like
    The TTi 2 inch have a bunch of notes about fitting coilover cars with rack and opinion steering, possibly the 1 7/8 as well.
  9. #7
    Newb
    Join Date
    Apr 2006
    Posts
    17
    Post Thanks / Like
    I've got an HDK k member in mine. I have TTI's in it. They fit great! Plenty of room. I figured I put quite a bit of money into the car, the headers should be quality as well.
  10. #8
    Junior Member warrendodge's Avatar
    Join Date
    Mar 2012
    Location
    Auckland New Zealand
    Posts
    82
    Post Thanks / Like
    I also have a HDK suspension with rack have 2'' TTI headers no fitment issues at all you spend a lot of money on the car and engine so why not buy the best in headers it will be cheaper in the long run
Posting Permissions
  • You may not post replies
  • You may not edit your posts
