Gas Tank filler Neck question
Results 1 to 2 of 2
Thread: Gas Tank filler Neck question
  1. #1
    Full Member smallbigblock's Avatar
    Join Date
    Jun 2007
    Location
    Wilsonville, OR
    Posts
    231
    Post Thanks / Like
    OK This might sound dumb to some of you guys, but I can't remember how the filler neck goes into the fuel tank. Does it go in from the outside the car, through the hole in the 1/4 pnl then into the tank. Or does it mount up to the hole from inside the trunk.
    From the outside seems to make more sense but just want to be sure.
    “I Saw Elvis at 1000 Feet”
    John Force
  2. #2
    Join Date
    Jun 2007
    Location
    Wilsonville, OR
    Posts
    231
    Post Thanks / Like
    Dumber Than I thought
    Well never mind I solved that by looking at the filler pipe. Stuff on the Pipe won't fit thru the hole (Vent, etc)
    John Force
Posting Permissions
  • You may not post replies
  • You may not edit your posts
